[Qgis-user] qgis 3.2 attribute table thousand separator
    Andreas Wicht
    a.wicht at gmail.com
    Fri Jun 29 02:28:36 PDT 2018
> QGIS now respects user's locale taken from the operating system settings, you can choose a different thousand separator or omit it completely by modifying the settings in your operating system (QGIS restart is required).
> Eventually, we could implement these settings as overrides at the application level for a more fine grained control.
Would it be possible to implement this only to influence the
representation of the number? This is how I see other software
products have solved this issue. Separators being copied is probably
very rarely desired by the user.
greetings
