[Qgis-user] QGIS and ESRI's ArcMAp
Kurt Menke
kurt at birdseyeviewgis.com
Fri Jun 29 07:34:28 PDT 2018
Hi Scott,
Off the top of my head, these are some features QGIS has that ArcMap
doesn't have:
- Live layer effects
- Blending modes
- Unique renderers for points like point cluster, point displacement &
heatmap
- Unique renderers for polygons like inverted polygons & 2.5D
- Hillshade renderer for elevation data
- Much better color picker interface with options not available in ArcMap
- More unique sub-renders which can be used in combination with the
above: Geometry generators, outline marker line, outline arrow...
- Styling dock
- Support for a much wider array of vector and raster file formats (by
an order of magnitude) including support for PostGIS, SpatiaLite, MSSQL,
Oracle, DB2, Geonode...
- QGIS is 64 bit vs 32 bit for ArcMap
- QGIS has a significantly larger array of expression functions
available which are available throughout the interface including data
defined overrides
- Global, Project and Layer Variables
- Virtual Layers
- In Esri speak what basically amounts to automatic annotation
- Multiple maps per project file
- Preview of valid bounds of a CRS
Kurt
Bird’s Eye View
3016 Santa Clara Ave SE
Albuquerque, NM 87106
www.BirdsEyeViewGIS.com <http://www.birdseyeviewgis.com/>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180629/2cf6061b/attachment.html>
