[Qgis-user] mac qgis3 binary errors
    Adam Dershowitz
    dersh at alum.mit.edu
    Thu May  3 07:53:29 PDT 2018
I downloaded the mac qgis3 binary.  I also installed the official python 3.6.  Whenever I first launch qgis I get a series of errors that pop up and look like this:
Couldn't load plugin 'FreehandRasterGeoreferencer' due to an error when calling its classFactory() method
ModuleNotFoundError: No module named 'osgeo'
  File "/Applications/QGIS3.app/Contents/MacOS/../Resources/python/qgis/utils.py", line 336, in startPlugin
    plugins[packageName] = package.classFactory(iface)
  File "/Users/adershowitz/Library/Application Support/QGIS/QGIS3/profiles/default/python/plugins/FreehandRasterGeoreferencer/__init__.py", line 24, in classFactory
    from .freehandrastergeoreferencer import FreehandRasterGeoreferencer
  File "/Applications/QGIS3.app/Contents/MacOS/../Resources/python/qgis/utils.py", line 664, in _import
    mod = _builtin_import(name, globals, locals, fromlist, level)
  File "/Users/adershowitz/Library/Application Support/QGIS/QGIS3/profiles/default/python/plugins/FreehandRasterGeoreferencer/freehandrastergeoreferencer.py", line 20, in
    from .freehandrastergeoreferencer_layer import (
  File "/Users/adershowitz/Library/Application Support/QGIS/QGIS3/profiles/default/python/plugins/FreehandRasterGeoreferencer/freehandrastergeoreferencer_layer.py", line 16, in
    from osgeo import gdal
Python version: 3.6.5 (v3.6.5:f59c0932b4, Mar 28 2018, 03:03:55) [GCC 4.2.1 (Apple Inc. build 5666) (dot 3)]
QGIS version: 3.0.2-Girona Girona, exported
Python Path:
/Applications/QGIS3.app/Contents/MacOS/../Resources/python/plugins
/Library/Frameworks/Python.framework/Versions/3.6/lib/python36.zip
/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6
/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/lib-dynload
/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/site-packages
Then three more:
Couldn't load plugin 'profiletool' due to an error when calling its classFactory() method
ModuleNotFoundError: No module named 'numpy'
Couldn't load plugin 'processing'
ModuleNotFoundError: No module named 'psycopg2'
Couldn't load plugin 'MetaSearch' due to an error when calling its classFactory() method
ModuleNotFoundError: No module named 'owslib'
Is there something that is missing.  I had tried to use the macports version of qgis3, and didn’t see these errors (although I did get other errors).  Then, once I close each dialog box, it opens and works.  But, the vector and raster menus don’t show many entries (while they did with the macports version).
When I installed python 3.6, I only installed the framework.  I didn’t include the optional installs such as:  GUI applications, command line tools, documentation, shell profile updater, or pip.    Could that be causing the problem?  If not, is there something else about plugins that I have to fix?
--Adam
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180503/04179470/attachment.html>
