[Qgis-user] Road network download
Etienne Trimaille etienne.trimaille at gmail.com
Fri May 4 10:19:14 PDT 2018
Sorry, I fail to understand. With OSM data in QGIS, you have the 'oneway'
column in the attribute table. If the field is empty, it means either OSM
doesn't have data for that road or by default it's not oneway.
https://wiki.openstreetmap.org/wiki/Key:oneway oneway=no is the default so
OSM contributors let this field empty. (only to avoid a confusion in some
areas).
2018-05-04 13:10 GMT-04:00 Xristos Xristoou <saxri89 at gmail.com>:
> Hello
> I need to download road network to used for travel problems.
> In that road i need to have details for oneways connections.
> I try to use OSM download QGIS plugin to take the roads but that data dont
> have direction details for oneway road connections.
> Any idea ?
> Thank you
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180504/39adff74/attachment.html>
