[Qgis-user] Road network download
Xristos Xristoou
saxri89 at gmail.com
Fri May 4 10:24:56 PDT 2018
I have oneway field with value -1,1,yes and no .but that values is in lines
and i cant understand connections for oneways
Στις Παρ, 4 Μαΐ 2018 - 20:19 ο χρήστης Etienne Trimaille <
etienne.trimaille at gmail.com> έγραψε:
> Sorry, I fail to understand. With OSM data in QGIS, you have the 'oneway'
> column in the attribute table. If the field is empty, it means either OSM
> doesn't have data for that road or by default it's not oneway.
> https://wiki.openstreetmap.org/wiki/Key:oneway oneway=no is the default
> so OSM contributors let this field empty. (only to avoid a confusion in
> some areas).
> 2018-05-04 13:10 GMT-04:00 Xristos Xristoou <saxri89 at gmail.com>:
>> Hello
>> I need to download road network to used for travel problems.
>> In that road i need to have details for oneways connections.
>> I try to use OSM download QGIS plugin to take the roads but that data
>> dont have direction details for oneway road connections.
>> Any idea ?
>> Thank you
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180504/618c19ec/attachment.html>
