[Qgis-user] Problem georeferencing images in UTM
    Carlos Henrique Grohmann de Carvalho
    carlos.grohmann at gmail.com
    Thu May 17 16:53:32 PDT 2018
Thanks for the input Nicolas
These are official maps so the utm grid is ok. I figured that I was using a
linear transformation, with the option to just create the world file, which
works for control points at the corners (lat/long), since the boundaries of
the map is defined by latitude/longitude. With UTM, this simple
transformation won't work, but TPS will give the correct results.
Carlos
On Thu, May 17, 2018 at 7:28 PM, Nicolas Cadieux <
nicolas.cadieux at archeotec.ca> wrote:
> Hi,
> The utm grid is way off or we have the wrong epsg code.  If you geofence
> using 2 points (linear algo)  using a service like google earth, you will
> see the distortion.  The long lat coordinate are probably ok but I did not
> test them.
> You can either use the long lat or use more points.  With 4 points and
> using the thin plate spline, I got good results.
> Nicolas
> Le 17 mai 2018 à 12:42, Carlos Henrique Grohmann de Carvalho <
> carlos.grohmann at gmail.com> a écrit :
> Thanks Nicolas, but the misalignment still persists. OTF is off, project
> has same CRS as data (epsg 29192). There is a ~400m difference in the N-S
> direction.
> Carlos
> On Thu, May 17, 2018 at 1:28 PM, Nicolas Cadieux <
>> Hi,
>> Disable projection on the fly.  Make sure the project is in the same CRS
>> as your maps.
>> Nicolas
>> Le 17 mai 2018 à 12:14, Carlos Henrique Grohmann de Carvalho <
>> Hello all
>> I have two pngs of topographic maps from southeastern Brazil (a zip file
>> with images and points is available here: https://www.dropbox.com/
>> s/mexeh4be46pgsk6/images_georef.zip?dl=0)
>> I'm trying to georeference them, but with partial success only. In this
>> image (https://www.dropbox.com/s/37xxqp4fkwpdyqh/utm_error.png?dl=0) you
>> can see that the X coordinate is fine, but the Y coordinate of the two maps
>> won't match.
>> Both maps use South American Datum 1969. I selected points near the
>> edges, and used the UTM values.
>> Interestingly, if I use Lat/Long, and place the points at the corners,
>> using decimal degrees, the maps align perfectly.
>> Any help is appreciated
>> Prof. Carlos Henrique Grohmann
>> Institute of Energy and Environment - Univ. of São Paulo, Brazil
>> - Digital Terrain Analysis | GIS | Remote Sensing -
>> http://carlosgrohmann.com
>> http://orcid.org/0000-0001-5073-5572
>> ________________
>> Can’t stop the signal.
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> ________________
________________
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180517/89ba44f3/attachment.html>
