[Qgis-user] Problem georeferencing images in UTM
listsen at 0x906.com
Thu May 17 21:28:23 PDT 2018
I haven't been able to open the dataset but going through the discussion
I would like to offer some assistance since I believe there are some
misconceptions here:
First, the data has nothing to do with the NAD27 / NAD83 datum's since
these are North American datum's and they don't apply I believe in South
America. Moreover, the separation between NAD27 to NAD83 is about 100m.
I think Carlos mention something like being 400m off.
Another point of confusion is about the projection of Google Earth.
Google is using a Web Mercator projection based on a perfect sphere.
This has nothing to do with the UTM that has already incorporate the
Earth Flattening values into the Northing and Easting equations.
If I find some time tomorrow, I will come back and give the proper
equations showing the difference between Google's projection and UTM.
-0x906
On 2018-05-17 19:53, Carlos Henrique Grohmann de Carvalho wrote:
> Thanks for the input Nicolas
> These are official maps so the utm grid is ok. I figured that I was using a linear transformation, with the option to just create the world file, which works for control points at the corners (lat/long), since the boundaries of the map is defined by latitude/longitude. With UTM, this simple transformation won't work, but TPS will give the correct results.
> Carlos
> On Thu, May 17, 2018 at 7:28 PM, Nicolas Cadieux <nicolas.cadieux at archeotec.ca> wrote:
> Hi,
> The utm grid is way off or we have the wrong epsg code. If you geofence using 2 points (linear algo) using a service like google earth, you will see the distortion. The long lat coordinate are probably ok but I did not test them.
> You can either use the long lat or use more points. With 4 points and using the thin plate spline, I got good results.
> Nicolas
> Le 17 mai 2018 à 12:42, Carlos Henrique Grohmann de Carvalho <carlos.grohmann at gmail.com> a écrit :
> Thanks Nicolas, but the misalignment still persists. OTF is off, project has same CRS as data (epsg 29192). There is a ~400m difference in the N-S direction.
> Carlos
> On Thu, May 17, 2018 at 1:28 PM, Nicolas Cadieux <nicolas.cadieux at archeotec.ca> wrote:
> Hi,
> Disable projection on the fly. Make sure the project is in the same CRS as your maps.
> Nicolas
> Le 17 mai 2018 à 12:14, Carlos Henrique Grohmann de Carvalho <carlos.grohmann at gmail.com> a écrit :
> Hello all
> I have two pngs of topographic maps from southeastern Brazil (a zip file with images and points is available here: https://www.dropbox.com/s/mexeh4be46pgsk6/images_georef.zip?dl=0 [1])
> I'm trying to georeference them, but with partial success only. In this image (https://www.dropbox.com/s/37xxqp4fkwpdyqh/utm_error.png?dl=0 [2]) you can see that the X coordinate is fine, but the Y coordinate of the two maps won't match.
> Both maps use South American Datum 1969. I selected points near the edges, and used the UTM values.
> Interestingly, if I use Lat/Long, and place the points at the corners, using decimal degrees, the maps align perfectly.
> Any help is appreciated
> Prof. Carlos Henrique Grohmann
> Institute of Energy and Environment - Univ. of São Paulo, Brazil
> - Digital Terrain Analysis | GIS | Remote Sensing -
> http://carlosgrohmann.com [3]
> http://orcid.org/0000-0001-5073-5572 [4]
> ________________
> Can't stop the signal.
> Qgis-user mailing list
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user [5]
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user [5]
________________
________________
Links:
[1] https://www.dropbox.com/s/mexeh4be46pgsk6/images_georef.zip?dl=0
[2] https://www.dropbox.com/s/37xxqp4fkwpdyqh/utm_error.png?dl=0
[3] http://carlosgrohmann.com/
[4] http://orcid.org/0000-0001-5073-5572
[5] https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180518/ec00b128/attachment.html>
