[Qgis-user] results Measure Tool vs. length()
Springfield Harrison stellargps at gmail.com
Thu May 17 17:51:31 PDT 2018
Interesting and alarming observation.
And how do those results compare with output from the $length variable?
Cheers . . . . .   Springfield
Samsung Tab 4
On May 17, 2018 5:26 AM, "Michel Stuyts" <michel.stuyts at edegem.be> wrote:
> In the length() function QGIS uses the CRS unit of the layer to calculate
> the result. When I use for example a layer in a local CRS like EPSG:31370
> or EPSG:5439 and a layer in EPSG:3857 (that all use meters as unit) the
> results are very different (+40% difference). Changing the project CRS
> makes no difference. When I check the length using the Measure Tool the
> results are very similar to the local CRS.
> How can I measure the length of a line and use it as a label independent
> from the layer CRS and get results similar to the results of the Measure
> Tool?
> Michel
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180517/9fd62a89/attachment.html>
