[Qgis-user] Problem georeferencing images in UTM
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Fri May 18 13:30:57 PDT 2018
NAD27 does touch the northern part of South America but you are correct
in saying that it does not extend in Brazil.  I wrote the comments when
I was still trying to figure out where the maps were in the world.  I
often get problems with NAD27 vs NAD83 grid in Canada as many maps have
been printed with the errors in NAD27 military grid reference system.
In those cases, error in much bigger than the standard 30 to 100 metres
error so that was my working hypotheses.   People assume that adjoining
maps use the same CRS and that is often not the case in remote areas.
I was reprojecting the Google map image to the local CRS in order to
figure out the distortion and not using the  WGS 84 Pseudo Merc
coordinates. It's important, like to say to know that there are
differences between the web merc and the various  WGS 84 realizations.
I would like to see the numbers out of curiosity if you have them. I
often wonder why these projections were invented.
BTW, the problem was solved when we used the TPS transformation and not
the linear transformation.
Cheers,
Nicolas
On 2018-05-18 3:52 PM, Nicolas Cadieux wrote:
> Le 18 mai 2018 à 00:28, <listsen at 0x906.com <mailto:listsen at 0x906.com>>
> <listsen at 0x906.com <mailto:listsen at 0x906.com>> a écrit :
>> I haven't been able to open the dataset but going through the
>> discussion I would like to offer some assistance since I believe
>> there are some misconceptions here:
>> First, the data has nothing to do with the NAD27 / NAD83 datum's
>> since these are North American datum's and they don't apply I believe
>> in South America. Moreover, the separation between NAD27 to NAD83 is
>> about 100m. I think Carlos mention something like being 400m off.
>> Another point of confusion is about the projection of Google Earth.
>> Google is using a Web Mercator projection based on a perfect sphere.
>> This has nothing to do with the UTM that has already incorporate the
>> Earth Flattening values into the Northing and Easting equations.
>> If I find some time tomorrow, I will come back and give the proper
>> equations showing the difference between Google's projection and UTM.
>> -0x906
>> On 2018-05-17 19:53, Carlos Henrique Grohmann de Carvalho wrote:
>>> Thanks for the input Nicolas
>>> These are official maps so the utm grid is ok. I figured that I was
>>> using a linear transformation, with the option to just create the
>>> world file, which works for control points at the corners
>>> (lat/long), since the boundaries of the map is defined by
>>> latitude/longitude. With UTM, this simple transformation won't work,
>>> but TPS will give the correct results.
>>> Carlos
>>> On Thu, May 17, 2018 at 7:28 PM, Nicolas Cadieux
>>> <nicolas.cadieux at archeotec.ca <mailto:nicolas.cadieux at archeotec.ca>>
>>> wrote:
>>>     Hi,
>>>     The utm grid is way off or we have the wrong epsg code.  If you
>>>     geofence using 2 points (linear algo)  using a service like
>>>     google earth, you will see the distortion.  The long lat
>>>     coordinate are probably ok but I did not test them.
>>>     You can either use the long lat or use more points.  With 4
>>>     points and using the thin plate spline, I got good results.
>>>     Nicolas
>>>     Le 17 mai 2018 à 12:42, Carlos Henrique Grohmann de Carvalho
>>>     <carlos.grohmann at gmail.com <mailto:carlos.grohmann at gmail.com>> a
>>>     écrit :
>>>>     Thanks Nicolas, but the misalignment still persists. OTF is
>>>>     off, project has same CRS as data (epsg 29192). There is a
>>>>     ~400m difference in the N-S direction.
>>>>     Carlos
>>>>     On Thu, May 17, 2018 at 1:28 PM, Nicolas Cadieux
>>>>     <mailto:nicolas.cadieux at archeotec.ca>> wrote:
>>>>         Hi,
>>>>         Disable projection on the fly.  Make sure the project is in
>>>>         the same CRS as your maps.
>>>>         Nicolas
>>>>         Le 17 mai 2018 à 12:14, Carlos Henrique Grohmann de
>>>>         Carvalho <carlos.grohmann at gmail.com
>>>>         <mailto:carlos.grohmann at gmail.com>> a écrit :
>>>>>         Hello all
>>>>>         I have two pngs of topographic maps from southeastern
>>>>>         Brazil (a zip file with images and points is available
>>>>>         here:
>>>>>         https://www.dropbox.com/s/mexeh4be46pgsk6/images_georef.zip?dl=0
>>>>>         <https://www.dropbox.com/s/mexeh4be46pgsk6/images_georef.zip?dl=0>)
>>>>>         I'm trying to georeference them, but with partial success
>>>>>         only. In this image
>>>>>         (https://www.dropbox.com/s/37xxqp4fkwpdyqh/utm_error.png?dl=0
>>>>>         <https://www.dropbox.com/s/37xxqp4fkwpdyqh/utm_error.png?dl=0>)
>>>>>         you can see that the X coordinate is fine, but the Y
>>>>>         coordinate of the two maps won't match.
>>>>>         Both maps use South American Datum 1969. I selected points
>>>>>         near the edges, and used the UTM values.
>>>>>         Interestingly, if I use Lat/Long, and place the points at
>>>>>         the corners, using decimal degrees, the maps align perfectly.
>>>>>         Any help is appreciated
>>>>>         Prof. Carlos Henrique Grohmann
>>>>>         Institute of Energy and Environment - Univ. of São Paulo,
>>>>>         Brazil
>>>>>         - Digital Terrain Analysis | GIS | Remote Sensing -
>>>>>         http://carlosgrohmann.com <http://carlosgrohmann.com/>
>>>>>         http://orcid.org/0000-0001-5073-5572
>>>>>         <http://orcid.org/0000-0001-5073-5572>
>>>>>         ________________
>>>>>         Can't stop the signal.
>>>>>         _______________________________________________
>>>>>         Qgis-user mailing list
>>>>>         Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>>>>>         List info:
>>>>>         https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>>         <https://lists.osgeo.org/mailman/listinfo/qgis-user>
>>>>>         Unsubscribe:
>>>>     Institute of Energy and Environment - Univ. of São Paulo, Brazil
>>>>     ________________
>>> ________________
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180518/ea5a5dee/attachment.html>
