[Qgis-user] Output CRS error from QGIS server 3.0.2
galebellego
galebellego.ext at orange.com
Tue May 22 01:43:40 PDT 2018
Hello Joshua,
do you still have your problem about the invalid CRS ?
I am far from being a QGIS expert, but I encountered such a problem a few
weeks ago (building a qgis 2.18 docker image).
So, if you still have your problem, here's what's worked for me .
First, try to have a look at your container (provided this is a standard
build!)
docker exec -itu root <your_container> ls /usr/share/qgis/resources/
You should see at least those 2 databases :
• srs-template.db
• srs.db
The second one is copied from the first in a post-install directive of one
of the .deb package : qgis-providers-common_x.xx.xx~stretch1_all.deb
If you do not install the package at once (apt-install *.deb), the directive
may be executed before the srs-template is copied, leading to your problem :
srs.db will be missing, and it is the one that holds all CRS/SRS.
Provied it is your pb, trying to fix the build order is the solution, but
you can also perform the copy from within your Dockerfile as a workaround.
Hope it helps!
Gaël
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
