[Qgis-user] [Inquiry]: Loading thermal image in QGIS
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Tue May 22 04:54:31 PDT 2018
I suggest you load the value tool plugin to get local pixel values.  I have no idea what image format you are using so I can’t help you much.  It would be nice to have a sample.  In the layer properties, you can select what bands to use.  Perhaps a you have band 123 for rGB and other bands for the thermal info?
File formats accepted by Qgis are those ( to my knowledge) accepted by gdal.
http://www.gdal.org/formats_list.html
Nicolas
> Le 22 mai 2018 à 02:49, Eunice Renovalles <emrenovalles at gmail.com> a écrit :
> Good day!
> I am a new to using QGIS 2.18.19 (I also have QGIS 3.0.3) and I use this program for a project involving thermal image processing. My thermal images were acquired using Flir Vue Pro R camera. My aim was to recolor the image based on its temperature.
> I initially tried loading the thermal image in QGIS; however, the thermal/radiometric data was gone when I used Identify Features tool, and instead showed the RGB value per pixel.
> I would like to inquire if it is possible to process thermal image in QGIS and how to retain the thermal data upon loading it in the software. I am able to extract the csv file thermal data of the image if ever it is needed.
> Your reply would be greatly appreciated.
> Regards,
> Eunice
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180522/5710f4cb/attachment.html>
