[Qgis-user] QGIS 3 errors after install on macOS 10.13.4
Reg Maltais reginald.maltais at gmail.com
Tue May 22 17:37:12 PDT 2018
The python version I installed was the “older” 10.6 version of python.
pyp version is "pip 10.0.1 from /Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/site-packages/pip (python 3.6)"
My macOS version is 10.13.4.
I’m willing to install all the modules manually if you want me to run some tests for you.
Thanks.
> On May 22, 2018, at 8:04 PM, William Kyngesburye <woklist at kyngchaos.com> wrote:
> The latest pip, as used to install Python modules, has a problem that affects some people.  I haven't figured out a definite solution, but there is a workaround that means manually installing all the python modules.  Or you can wait for QGIS 3.0.3 - at least I'll use the workaround in the installers.
> You can help me with some information:
> - what version of Python did you install?  specifically, which system version?  Starting with Python 3.6.5, there are now 2 installers: one for older OS X systems, it has "macosx10.6" in the installer name (this is how all previous versions were built), and one for newer systems, it has macosx10.9 in the installer name.
> - which version of pip is installed?  you can check from a Terminal with:
>   pip3 -V
> - your macOS version
>> On May 22, 2018, at 6:23 PM, Reg Maltais <reginald.maltais at gmail.com <mailto:reginald.maltais at gmail.com>> wrote:
>> Hi,
>> I’ve run a complete install of Python 3 (python-3.6.5-macos10.6.pkg), GDAL complete, then QGIS 3.0.2. When I open QGIS I get the error below. I found a thread that has a similar error, and the fix was to reinstall all the components, but I’ve done this a few times now to no avail (both overwriting QGIS3.app and after deleting it). I’ve also set $PATH to prepend "/Library/Frameworks/Python.framework/Versions/3.6/bin:/Library/Frameworks/GDAL.framework/Versions/2.2/Programs:” in the environment settings.
>> I went and looked into /Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/site-package, and sure enough there is no ‘osgeo’. Other things like ‘psycopg2’ are there though, but for whatever reason not osgeo. Any ideas would be appreciated.
>> Couldn't load plugin 'processing'
>> ModuleNotFoundError: No module named 'osgeo'
>> Traceback (most recent call last):
>>   File "/Applications/QGIS3.app/Contents/MacOS/../Resources/python/qgis/utils.py", line 311, in loadPlugin
>>     __import__(packageName)
>>   File "/Applications/QGIS3.app/Contents/MacOS/../Resources/python/qgis/utils.py", line 664, in _import
>>     mod = _builtin_import(name, globals, locals, fromlist, level)
>>   File "/Applications/QGIS3.app/Contents/MacOS/../Resources/python/plugins/processing/__init__.py", line 28, in
>>     from processing.tools.dataobjects import *          # NOQA
>>   File "/Applications/QGIS3.app/Contents/MacOS/../Resources/python/plugins/processing/tools/dataobjects.py", line 51, in
>>     from processing.algs.gdal.GdalUtils import GdalUtils
>>   File "/Applications/QGIS3.app/Contents/MacOS/../Resources/python/plugins/processing/algs/gdal/GdalUtils.py", line 35, in
>>     from osgeo import gdal
>> Python version: 3.6.5 (v3.6.5:f59c0932b4, Mar 28 2018, 03:03:55) [GCC 4.2.1 (Apple Inc. build 5666) (dot 3)]
>> QGIS version: 3.0.2-Girona Girona, exported
>> Python Path:
>> /Users/goatsweater/Library/Application Support/QGIS/QGIS3/profiles/default/python
>> /Users/goatsweater/Library/Application Support/QGIS/QGIS3/profiles/default/python/plugins
>> /Library/Frameworks/Python.framework/Versions/3.6/lib/python36.zip
>> /Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/lib-dynload
>> Thanks,
>> Reg
>> Qgis-user mailing list
>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/ <http://www.kyngchaos.com/>
> "Time is an illusion - lunchtime doubly so."
> - Ford Prefect
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180522/d740d552/attachment.html>
