[Qgis-user] QGIS 3 errors after install on macOS 10.13.4
William Kyngesburye
woklist at kyngchaos.com
Tue May 22 17:50:11 PDT 2018
Try installing the 10.9 version of Python.
Then reinstall GDAL and QGIS.
> On May 22, 2018, at 7:37 PM, Reg Maltais <reginald.maltais at gmail.com> wrote:
> The python version I installed was the “older” 10.6 version of python.
> pyp version is "pip 10.0.1 from /Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/site-packages/pip (python 3.6)"
> My macOS version is 10.13.4.
> I’m willing to install all the modules manually if you want me to run some tests for you.
> Thanks.
>> On May 22, 2018, at 8:04 PM, William Kyngesburye <woklist at kyngchaos.com <mailto:woklist at kyngchaos.com>> wrote:
>> The latest pip, as used to install Python modules, has a problem that affects some people. I haven't figured out a definite solution, but there is a workaround that means manually installing all the python modules. Or you can wait for QGIS 3.0.3 - at least I'll use the workaround in the installers.
>> You can help me with some information:
>> - what version of Python did you install? specifically, which system version? Starting with Python 3.6.5, there are now 2 installers: one for older OS X systems, it has "macosx10.6" in the installer name (this is how all previous versions were built), and one for newer systems, it has macosx10.9 in the installer name.
>> - which version of pip is installed? you can check from a Terminal with:
>> pip3 -V
>> - your macOS version
>>> On May 22, 2018, at 6:23 PM, Reg Maltais <reginald.maltais at gmail.com <mailto:reginald.maltais at gmail.com>> wrote:
>>> Hi,
>>> I’ve run a complete install of Python 3 (python-3.6.5-macos10.6.pkg), GDAL complete, then QGIS 3.0.2. When I open QGIS I get the error below. I found a thread that has a similar error, and the fix was to reinstall all the components, but I’ve done this a few times now to no avail (both overwriting QGIS3.app and after deleting it). I’ve also set $PATH to prepend "/Library/Frameworks/Python.framework/Versions/3.6/bin:/Library/Frameworks/GDAL.framework/Versions/2.2/Programs:” in the environment settings.
>>> I went and looked into /Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/site-package, and sure enough there is no ‘osgeo’. Other things like ‘psycopg2’ are there though, but for whatever reason not osgeo. Any ideas would be appreciated.
>>> Couldn't load plugin 'processing'
>>> ModuleNotFoundError: No module named 'osgeo'
>>> Traceback (most recent call last):
>>> File "/Applications/QGIS3.app/Contents/MacOS/../Resources/python/qgis/utils.py", line 311, in loadPlugin
>>> __import__(packageName)
>>> File "/Applications/QGIS3.app/Contents/MacOS/../Resources/python/qgis/utils.py", line 664, in _import
>>> mod = _builtin_import(name, globals, locals, fromlist, level)
>>> File "/Applications/QGIS3.app/Contents/MacOS/../Resources/python/plugins/processing/__init__.py", line 28, in
>>> from processing.tools.dataobjects import * # NOQA
>>> File "/Applications/QGIS3.app/Contents/MacOS/../Resources/python/plugins/processing/tools/dataobjects.py", line 51, in
>>> from processing.algs.gdal.GdalUtils import GdalUtils
>>> File "/Applications/QGIS3.app/Contents/MacOS/../Resources/python/plugins/processing/algs/gdal/GdalUtils.py", line 35, in
>>> from osgeo import gdal
>>> Python version: 3.6.5 (v3.6.5:f59c0932b4, Mar 28 2018, 03:03:55) [GCC 4.2.1 (Apple Inc. build 5666) (dot 3)]
>>> QGIS version: 3.0.2-Girona Girona, exported
>>> Python Path:
>>> /Users/goatsweater/Library/Application Support/QGIS/QGIS3/profiles/default/python
>>> /Users/goatsweater/Library/Application Support/QGIS/QGIS3/profiles/default/python/plugins
>>> /Library/Frameworks/Python.framework/Versions/3.6/lib/python36.zip
>>> /Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/lib-dynload
>>> Thanks,
>>> Reg
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user <https://lists.osgeo.org/mailman/listinfo/qgis-user>
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user <https://lists.osgeo.org/mailman/listinfo/qgis-user>
>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>> http://www.kyngchaos.com/ <http://www.kyngchaos.com/>
>> "Time is an illusion - lunchtime doubly so."
>> - Ford Prefect
Theory of the Universe
There is a theory which states that if ever anyone discovers exactly what the universe is for and why it is here, it will instantly disappear and be replaced by something even more bizarrely inexplicable. There is another theory which states that this has already happened.
-Hitchhiker's Guide to the Galaxy 2nd season intro
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180522/64b4a33f/attachment.html>
