[Qgis-user] layers shift when exporting from composer to jpg
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Wed May 30 04:40:53 PDT 2018
I had this problem with openlayer plugin before when I zoomed in to much and then printed. I use QuickMapServices plugin now that does not do that. Using a wms should fix the problem also.
Nicolas
> Le 30 mai 2018 à 06:37, Martin Fisher <martin.pescador at inventati.org> a écrit :
> I do not know why you have encountered this problem, but perhaps you could try and alternative approach, depending on what you could like on the background. The obvious choice may be to use an ESRI map service from http://server.arcgisonline.com/arcgis/rest/services, as a WMS layer.
> Best of luck
> On May 28 2018, at 3:57 pm, MIKE MCGRADY <mikemcgrady at hotmail.com> wrote:
> I wanted to make a quick map using composer using a google hybrid map as background. Everything looked fine in the preview, but when I looked at the jpg, the data were no longer in the right space, having shifted some few km to the west. I am using QGIS 2.8.3 Wien. Am I missing something? Any work around?
> I am not very experienced with QGIS, so simple instructions work best (in all things)
> M. J. McGrady
> Am Rosenhugel 59
> A-3500 Krems
> Austria
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180530/e829249d/attachment.html>
