[Qgis-user] Can't find Python
Clifford Snow
clifford at snowandsnow.us
Thu Nov 1 12:18:13 PDT 2018
Daniele,
Thanks - pip is likely the cause. I use pip often but have been ignoring
where pip installs. In the future I will be sure to use pip(3) --user. Now
I have to go through and reinstall a bunch of python modules.:-)
Snap may also contribute to the problem. Unfortunately Fedora doesn't
always have the apps needed or are badly out of date. For example I use
Nextcloud. Nextcloud version is currently 14.03. Fedora, last I checked, is
still on version 10.
Thanks for your help,
Clifford
On Thu, Nov 1, 2018 at 11:01 AM Daniele ViganĂ² <daniele at vigano.me> wrote:
> Hi Clifford,
> On Thu, Nov 1, 2018 at 6:29 PM Clifford Snow <clifford at snowandsnow.us>
> wrote:
>> I did use your package but didn't install the python3-qgis. After I
>> originally installed qgis, I went searching for a python qgis package but
>> must have missed it. Shouldn't it be required by the qgis rpm so it
>> installs as one of qgis's dependancies.
> no, python3-qgis isn't a requirement of QGIS, it's an optional dependency
> (like GRASS). It's true that QGIS without the python support is missing
> several extended features, but the main capabilities of QGIS do not depend
> on Python. This is well described both on the official documentation and on
> the repo welcome page (see 'Installing QGIS'); I'm also following the same
> path as the official Ubuntu/Debian packages do.
>> After installing python3-qgis python still isn't found. Now I get the
>> following warnings:
>> Couldn't load SIP module.
>> Python support will be disabled.
>> ImportError: /lib64/libQt5Core.so.5: version `Qt_5_PRIVATE_API' not
>> found (required by /usr/local/lib64/python3.6/site-packages/PyQt5/QtCore.so)
> The problem is here */usr/local/*lib64: it looks like you are not using
> the standard PyQt5 distribution available via the official Fedora RPMs
> (otherwise QtCore.so would be under /usr/lib64 and *NOT* /usr/*local*/lib64).
> It's probable that the QtCore version offered by
> /usr/local/lib64/python3.6/site-packages/PyQt5/QtCore.so doesn't match the
> one which QGIS is compiled against, which is 5.10:
> $ rpm -qf /usr/lib64/python3.6/site-packages/PyQt5/QtCore.so
> python3-qt5-base-5.10.1-4.fc28.x86_64
> You must make sure that QGIS is using the libraries provided by official
> Feodra RPMs or at least (even if still dangerous) versions of libraries are
> matching the same API level.
> Generally speaking overriding Python system libraries installed via RPMs
> is a bad idea. You should use virtualenvs instead (or the user prefix at
> least, like via pip --user) and leave the system clean.
> HTH,
> Daniele
> *Daniele ViganĂ²*
> http://daniele.vigano.me
@osm_seattle
osm_seattle.snowandsnow.us
OpenStreetMap: Maps with a human touch
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20181101/4965d3f0/attachment.html>
