[Qgis-user] Performance of MSSQL Server with QGIS 3.4
Nyall Dawson
nyall.dawson at gmail.com
Sun Nov 4 15:35:58 PST 2018
On Thu, 1 Nov 2018 at 01:55, Baker, Matthew <MATTHEW_BAKER at dpsk12.org> wrote:
> Thanks again, Nyall.
> Re. 'only look in geometry columns' - no, we're not using this setting, nor have we ever. Is that true that pre-3.4 was using that setting? I would have imagined this is the other way around? I will see if this fix addresses this issue when it gets implemented.
Pre 3.4 browser was ALWAYS using that logic, regardless of the
connection's setting. So it would have been nice and fast, but missing
tables which weren't present in the geometry_columns tables. (Note
that QGIS automatically creates this table and populates it
automatically during certain layer creation operations)
Nyall
> Re. the schema display for dragging and dropping - still not a fan of this feature - would prefer the QGIS browser window not be a DBA-type of GUI (https://issues.qgis.org/issues/17719) but that's another issue altogether!
> Thanks again!
> -m
> -----Original Message-----
> From: Nyall Dawson <nyall.dawson at gmail.com>
> Sent: Tuesday, October 30, 2018 6:48 PM
> To: Baker, Matthew <MATTHEW_BAKER at dpsk12.org>
> Cc: Andreas Neumann <andreas at qgis.org>; qgis-user <qgis-user at lists.osgeo.org>
> Subject: Re: [Qgis-user] Performance of MSSQL Server with QGIS 3.4
> On Wed, 31 Oct 2018 at 01:28, Baker, Matthew <MATTHEW_BAKER at dpsk12.org> wrote:
> > Thanks for the reply, Nyall.
> > To clarify - this issue is just refreshing the database tree in the browser window - once refreshed (eventually), all tables behave normally (see below re. invalid geometries).
> > 2.18 and 3.2 used to refresh the tables just fine. Upon installing 3.4, things have slowed down for all versions.
> Thanks for the clarification. Can you confirm whether you have the setting "only look in the geometry_columns metadata table" switched on or off for your connection?
> If you're not using this setting, then it's possibly related to this fix https://github.com/qgis/QGIS/commit/e813fe880. Pre 3.4 QGIS was only looking in the geometry columns table for the browser, and not respecting this setting.
> > Another thing to note - 2.18 and 3.2 show only a handful of schemas in the database (not sure how it decides which one) - but now 3.4 is showing ALL schemas, including those without any tables and that weren't shown in 2.18/3.2 - that's weird!
> That's intended -- for db connections we should be showing empty schemas in the browser, as this allows users to drag and drop tables into these schemas to initially populate them.
> Nyall
