[Qgis-user] Changing data source from Postgis to Geopackage
Andreas Neumann
a.neumann at carto.net
Mon Nov 5 06:17:48 PST 2018
Ok - I am doing it in the text editor.
I also had to change
<provider encoding="System">postgres</provider>
to
<provider encoding="System">ogr</provider>
After doing this change, it worked.
Andreas
On 2018-11-05 15:01, Alessandro Pasotti wrote:
> On Mon, Nov 5, 2018 at 2:54 PM Andreas Neumann <a.neumann at carto.net> wrote:
>> Hi,
>> I have a relatively complex QGIS project with data storage in QGIS and would like to change the data source of all layers to Geopackage.
>> I already have a Geopackage with the exact same data structure like in Postgis (automatic export from Postgis through ogr2ogr).
>> Now I wonder what the best approach is to change all data sources from Postgis to Geopackage?
>> Texteditor and search/replace or is there something more comfortable?
> Hi Andreas,
> you could first check if it works correctly with one layer, from the python console vl.changeDataSource('/my/new/path|layername=mylayername', 'layer_name', 'ogr')
> then exit without saving the project, make a backup and try search replace.
> Alessandro Pasotti
> w3: www.itopen.it [1]
Links:
[1] http://www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20181105/10f37219/attachment-0001.html>
