[Qgis-user] Changing data source from Postgis to Geopackage
Paolo Cavallini
cavallini at faunalia.it
Mon Nov 5 08:46:17 PST 2018
This seems a good candidate for an extra function of the browser.
Probably a simple Py script or a plugin should do, at least as a prototype.
Better add a ticket not to forget?
All the best.
Il 11/05/2018 03:17 PM, Andreas Neumann ha scritto:
> Hi,
> Ok - I am doing it in the text editor.
> I also had to change
> <provider encoding="System">postgres</provider>
> to
> <provider encoding="System">ogr</provider>
> After doing this change, it worked.
> Andreas
> On 2018-11-05 15:01, Alessandro Pasotti wrote:
>> On Mon, Nov 5, 2018 at 2:54 PM Andreas Neumann <a.neumann at carto.net
>> <mailto:a.neumann at carto.net>> wrote:
>> Hi,
>> I have a relatively complex QGIS project with data storage in
>> QGIS and would like to change the data source of all layers to
>> Geopackage.
>> I already have a Geopackage with the exact same data structure
>> like in Postgis (automatic export from Postgis through ogr2ogr).
>> Now I wonder what the best approach is to change all data sources
>> from Postgis to Geopackage?
>> Texteditor and search/replace or is there something more comfortable?
>> Hi Andreas,
>> you could first check if it works correctly with one layer, from the
>> python console
>> vl.changeDataSource('/my/new/path|layername=mylayername',
>> 'layer_name', 'ogr')
>> then exit without saving the project, make a backup and try search
>> replace.
>> Alessandro Pasotti
>> w3: www.itopen.it <http://www.itopen.it>
> Qgis-user mailing list
Paolo Cavallini - www.faunalia.eu
QGIS.ORG Chair:
http://planet.qgis.org/planet/user/28/tag/qgis%20board/
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20181105/5be13f70/attachment.html>
