[Qgis-user] Vector with more than xyzm
Matthias Kuhn
matthias at opengis.ch
Wed Nov 7 00:01:41 PST 2018
The closest you can get using a single table is using array typed
fields, but beware of editing data, nothing will prevent you from
corrupting the data and having geometry and attributes out of sync.
Other approaches are having a separate point layer with the vertices
duplicated or a linear referencing table.
Cheers
Matthias
On 11/7/18 5:34 AM, Idan Miara wrote:
> Hi,
> Thanks for your response!
> Please note that the extra info is per vertex and the features are
> multipolylines for instance. Think a file of airplane paths, so you
> have 6 dims per vertex and some attributes per path feature.
> On Wed, 7 Nov 2018, 05:34 Nicolas Cadieux
> <nicolas.cadieux at archeotec.ca <mailto:nicolas.cadieux at archeotec.ca> wrote:
> Hi,
> Well I believe the simple .csv file is not the fastest but will
> give you the most flexibility if you have a massive amount of
> data. I have been working with hyper spectral cloud data.
> Nicolas
> > Le 6 nov. 2018 à 21:09, Alex Mandel <tech_dev at wildintellect.com
> <mailto:tech_dev at wildintellect.com>> a écrit :
> >> On 11/6/18 12:54, Idan Miara wrote:
> >> Hi,
> >> What would be the OGR or the portable way for handling vector
> data with
> >> more than 4 dimensions?
> >> i.e. xyz+time+velocity+acceleration for each vertex.
> >> Kind regards,
> >> Idan
> > Attribute tables. Make XYZ geometries and put all your other
> stuff into
> > attributes.
> > Enjoy,
> > Alex
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
Matthias Kuhn
matthias at opengis.ch <mailto:matthias at opengis.ch>
+41 (0)76 435 67 63 <tel:+41764356763>
OPENGIS.ch Logo <http://www.opengis.ch>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20181107/2d08e1cb/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20181107/2d08e1cb/attachment.png>
