[Qgis-user] Vector with more than xyzm
Idan Miara
idan at miara.com
Thu Nov 8 13:51:10 PST 2018
Thanks for all your replies!
On Wed, 7 Nov 2018 at 10:01, Matthias Kuhn <matthias at opengis.ch> wrote:
> The closest you can get using a single table is using array typed fields,
> but beware of editing data, nothing will prevent you from corrupting the
> data and having geometry and attributes out of sync.
> Other approaches are having a separate point layer with the vertices
> duplicated or a linear referencing table.
> Cheers
> Matthias
> On 11/7/18 5:34 AM, Idan Miara wrote:
> Hi,
> Thanks for your response!
> Please note that the extra info is per vertex and the features are
> multipolylines for instance. Think a file of airplane paths, so you have 6
> dims per vertex and some attributes per path feature.
> On Wed, 7 Nov 2018, 05:34 Nicolas Cadieux <nicolas.cadieux at archeotec.ca
> wrote:
>> Hi,
>> Well I believe the simple .csv file is not the fastest but will give you
>> the most flexibility if you have a massive amount of data. I have been
>> working with hyper spectral cloud data.
>> Nicolas
>> > Le 6 nov. 2018 à 21:09, Alex Mandel <tech_dev at wildintellect.com> a
>> écrit :
>> >> On 11/6/18 12:54, Idan Miara wrote:
>> >> Hi,
>> >> What would be the OGR or the portable way for handling vector data with
>> >> more than 4 dimensions?
>> >> i.e. xyz+time+velocity+acceleration for each vertex.
>> >> Kind regards,
>> >> Idan
>> > Attribute tables. Make XYZ geometries and put all your other stuff into
>> > attributes.
>> > Enjoy,
>> > Alex
>> > _______________________________________________
>> > Qgis-user mailing list
>> > Qgis-user at lists.osgeo.org
>> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Qgis-user mailing listQgis-user at lists.osgeo.org
> Matthias Kuhn
> +41 (0)76 435 67 63 <+41764356763>
> [image: OPENGIS.ch Logo] <http://www.opengis.ch>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20181108/f440809e/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20181108/f440809e/attachment.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20181108/f440809e/attachment-0001.png>
