[Qgis-user] Execute SQL
Herbert Lincon
herbert_lincon_jau at hotmail.com
Tue Nov 6 13:11:28 PST 2018
Hello,
In QGIS 2.18.23, I´m using the model "Execute SQL" from the Tollbox to run the statment:
"SELECT * FROM input1 ORDER BY TALHAO ASC;"
where "TALHAO" is the name of a colum with integer values.
My issue is:
I made a Model with several steps, and I need to put this SQL statment in the middle of it,
but this process never accept a output as input.
For example: if the "Execute SQL" is the first step, it will execute normally,
but if it is not the first one, I got this error:
Error executing algorithm Execute SQL
virtual: Cannot find layer OUTPUTALGQGISDISSOLVE1_shp20181015165259558
Searching in the %temp% folder, this output file do exist!
I made another attempt,
with the SQL as first step,
if the input shape is named starting with letter, it will run
if the input name´s starts with number, a got this error:
virtual: Query execution error on DROP TABLE IF EXISTS "input1"; CREATE VIRTUAL TABLE "input1" USING QgsVLayer(81121_463_DE20181015165152041);: 1 - unrecognized token: "81121_463_DE20181015165152041"
I can´t understand why sometimes this algoritm run, and sometimes not
I would appreciate some help
Thanks for the Attention
______________________________________________
Herbert Lincon R. A. dos Santos
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20181106/b0f735ee/attachment-0001.html>
Type: image/png
Desc: sql.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20181106/b0f735ee/attachment-0001.png>
