[Qgis-user] QGIS - HTML
Herbert Lincon
herbert_lincon_jau at hotmail.com
Wed Nov 7 07:33:40 PST 2018
Hello Andreas,
Thanks for the help,
at work I develop some map canvas for the other users on the company,
in those maps, there are some labels that need to be edited in each map.
for now, the users select that label, go to properties and edit the content text
with the HTML, I would like that the user could edit the label directly clicking on it,
it would be faster and intuitive
______________________________________________
Herbert Lincon R. A. dos Santos
De: Andreas Neumann <a.neumann at carto.net>
Enviado: quarta-feira, 7 de novembro de 2018 05:28
Para: Herbert Lincon
Assunto: Re: [Qgis-user] QGIS - HTML
Hi Herbert,
I am not 100% sure - but the HTML frame in the QGIS print composer is not for interactive HTML. Yes - you can have an onload javascript (e.g. to create HTML content) - but it is not meant to be a full browser, but to print out existing or generated HTML content.
It is not meant to be interactive, e.g. with forms and such.
What are you trying to achieve? What is your use case with this form content in QGIS print composer?
Andreas
On 2018-11-06 22:15, Herbert Lincon wrote:
Hello,
I´m using QGIS 2.18.23, in the composer, I added a HTML frame with the <fildset> TAG,
like the print attached
but, the fieldset is not clickable, the same happens with the <textarea> TAG
could someone help or explain this?
Thanks for the atention
this is the code used
<form>
<fieldset>
<legend>Contact</legend>
<input type="text" size="50" maxlength="5" placeholder="Type your Name"/>
<textarea rows="3" cols="50" placeholder="Adress"></textarea>
</fieldset>
</form>
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20181107/2f54ba19/attachment.html>
