[Qgis-user] kriging proble.
Francois Chartier fra.chartier at gmail.com
Wed Nov 7 19:38:40 PST 2018
i am resending this email as my previous email was too big.
I am trying to krige particle size at a given elevation for some borehole
information, see log sheet below
I have tried IDW which provide an interpolation over the defined extent.
  I would like to use kriging however, when it takes probably 20 to 30 min
to run using ordinary kriking, or a few min with simple kriging, and the
resulting interpolation in both cases are limited to approx 1000 m from the
data points.  I presume that this is due to the search radius of 1km. This
data set is only 700 points and shouldn't be that complicated to krig.  The
range of the interpolation also is out of range of the data points.  I am
not sure what I am doing wrong..
SEE log sheet below
Processing algorithm…
Algorithm 'Simple kriging' starting…
Input parameters:
{ 'BLOCK' : False, 'DBLOCK' : 100, 'FIELD' : 'ParticleSize', 'LOG' : False,
'POINTS' : 'C:/Users/Francois
Chartier/Documents/GeoModel/Intervals/130.gpkg|layername=130', 'PREDICTION'
Chartier/AppData/Local/Temp/processing_ec36cad732be463eb755fc7f6e89232f/5906333ae6674718b7180ff8a8166ac2/PREDICTION.sdat',
'SEARCH_DIRECTION' : 0, 'SEARCH_POINTS_ALL' : 0, 'SEARCH_POINTS_MAX' : 20,
'SEARCH_POINTS_MIN' : 16, 'SEARCH_RADIUS' : 1000, 'SEARCH_RANGE' : 0,
'TARGET_TEMPLATE' : None, 'TARGET_USER_FITS' : 0, 'TARGET_USER_SIZE' : 100,
'TARGET_USER_XMIN TARGET_USER_XMAX TARGET_USER_YMIN TARGET_USER_YMAX' :
'651700, 609200, 4862000, 4825700', 'TQUALITY' : 0, 'VARIANCE' :
'C:/Users/Francois
Chartier/AppData/Local/Temp/processing_ec36cad732be463eb755fc7f6e89232f/30e93e365de34177a512d28cd8414007/VARIANCE.sdat',
'VAR_MAXDIST' : -1, 'VAR_MODEL' : 'a + b * x', 'VAR_NCLASSES' : 100,
'VAR_NSKIP' : 1 }
statistics_kriging "Simple Kriging" -TARGET_DEFINITION 0 -POINTS
"C:/Users/Francois
Chartier/AppData/Local/Temp/processing_ec36cad732be463eb755fc7f6e89232f/9c11d34a631749ec91b9206a6a513f7c/POINTS.shp"
-FIELD "ParticleSize" -TQUALITY 0 -LOG false -BLOCK false -DBLOCK 100.0
-VAR_MAXDIST -1.0 -VAR_NCLASSES 100 -VAR_NSKIP 1 -VAR_MODEL "a + b * x"
-TARGET_USER_XMIN 609200.0 -TARGET_USER_XMAX 651700.0 -TARGET_USER_YMIN
4825700.0 -TARGET_USER_YMAX 4862000.0 -TARGET_USER_SIZE 100.0
-TARGET_USER_FITS 0 -SEARCH_RANGE 0 -SEARCH_RADIUS 1000.0
-SEARCH_POINTS_ALL 0 -SEARCH_POINTS_MIN 16 -SEARCH_POINTS_MAX 20
-SEARCH_DIRECTION 0 -PREDICTION "C:/Users/Francois
Chartier/AppData/Local/Temp/processing_ec36cad732be463eb755fc7f6e89232f/5906333ae6674718b7180ff8a8166ac2/PREDICTION.sdat"
-VARIANCE "C:/Users/Francois
Chartier/AppData/Local/Temp/processing_ec36cad732be463eb755fc7f6e89232f/30e93e365de34177a512d28cd8414007/VARIANCE.sdat"
C:\PROGRA~1\QGIS3~1.4\bin>set SAGA=C:/PROGRA~1/QGIS3~1.4/apps\saga-ltr
SAGA_MLB=C:/PROGRA~1/QGIS3~1.4/apps\saga-ltr\modules
C:\PROGRA~1\QGIS3~1.4\bin>PATH=C:\PROGRA~1\QGIS3~1.4\apps\qgis\bin;C:\PROGRA~1\QGIS3~1.4\apps\grass\grass-7.4.2\lib;C:\PROGRA~1\QGIS3~1.4\apps\grass\grass-7.4.2\bin;C:\PROGRA~1\QGIS3~1.4\apps\Python37;C:\PROGRA~1\QGIS3~1.4\apps\Python37\Scripts;C:\PROGRA~1\QGIS3~1.4\apps\qt5\bin;C:\PROGRA~1\QGIS3~1.4\apps\Python27\Scripts;C:\PROGRA~1\QGIS3~1.4\bin;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\system32\WBem;C:\PROGRA~1\QGIS3~1.4\apps\Python37\lib\site-packages\pywin32_system32;C:\PROGRA~1\QGIS3~1.4\apps\Python37\lib\site-packages\numpy\.libs;C:/PROGRA~1/QGIS3~1.4/apps\saga-ltr;C:/PROGRA~1/QGIS3~1.4/apps\saga-ltr\modules
C:\PROGRA~1\QGIS3~1.4\bin>saga_cmd statistics_kriging "Simple Kriging"
-TARGET_DEFINITION 0 -POINTS "C:/Users/Francois
____________________________
SAGA Version: 2.3.2 (64 bit)
library path: C:\PROGRA~1\QGIS3~1.4\apps\saga-ltr\modules\
library name: statistics_kriging
library : Kriging
tool : Simple Kriging
author : O.Conrad (c) 2015
processors : 4 [4]
Parameters
Points: POINTS
Attribute: fid
Type of Quality Measure: standard deviation
Logarithmic Transformation: no
Block Kriging: no
Maximum Distance: -1.000000
Lag Distance Classes: 100
Skip: 1
Model: a + b * x
Target Grid System: user defined
Cellsize: 100.000000
Left: 609200.000000
Right: 651700.000000
Bottom: 4825700.000000
Top: 4862000.000000
Fit: nodes
Search Range: local
Maximum Search Distance: 1000.000000
Number of Points: maximum number of nearest points
Minimum: 16
Maximum: 20
Direction: all directions
a = 39510.6
b = 0.973903
Loading resulting layers
Algorithm 'Simple kriging' finished
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20181107/59a62893/attachment.html>
