[Qgis-user] Display Point with Show Labels
    Carlos Cerdán
    sig.upagu at gmail.com
    Tue Nov 13 06:00:30 PST 2018
What about to use scale interval? You're using view based on rules; then,
you can define scale intervals to show desired points (and their labels)
depending of scale.
Good luck,
Carlos
El mié., 7 nov. 2018 a las 17:13, Ian Reese (<ireese at linz.govt.nz>)
escribió:
> Hi QGIS,
> I have been researching for two days now and not sure if this achievable,
> but is it possible to only show points for the corresponding labels that
> are showing?  I have a rule based labeling structure for a layer.  I want
> to only show points for those labels showing.  I found this post from two
> years ago:
> https://gis.stackexchange.com/questions/217067/showing-only-point-markers-when-labels-are-shown-in-qgis
> suggesting it was not possible.  I was hoping this was may have been
> addressed in QGIS 3.0 or perhaps this is some programmatic solution I am
> missing.  Attached is screen shot of the issue.  Too many points for the
> labels.
> Cheers,
> Ian C Reese
> Senior Spatial Analyst
> Location Information Data Services
> E  ireese at linz.govt.nz | DDI 04 6504
> Wellington Office, Level 7, Radio New Zealand House, 155 The Terrace
> PO Box 5501, Wellington 6145, New Zealand | T 04 460 0110
> W  www.linz.govt.nz | www.landonline.govt.nz | data.linz.govt.nz
> <http://www.data.linz.govt.nz/>
> This message contains information, which may be in confidence and may be
> subject to legal privilege. If you are not the intended recipient, you must
> not peruse, use, disseminate, distribute or copy this message. If you have
> received this message in error, please notify us immediately (Phone 0800
> 665 463 or info at linz.govt.nz) and destroy the original message. LINZ
> accepts no responsibility for changes to this email, or for any
> attachments, after its transmission from LINZ. Thank You.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20181113/9abdb942/attachment.html>
