[Qgis-user] Geo package export/open problems
Samuel Williams
sam.williams at sineenvironmental.com
Sat Nov 17 07:21:36 PST 2018
I'm having trouble exporting a shapefile as a geo file... according to
the log it is written successfully, but when QGIS tries to open it and
add to the map it finds that it is invalid.
I've checked the geometry of the features and they are all reported to be valid.
**Update - seems to work fine when exporting to a test file in my home
directory. I've got owner and group access rights to the paths below
which are on a CIFS share, so perhaps it is something in the filename
which is illegal?**
2018-11-17T14:53:55 CRITICAL Invalid Data Source :
/home/samw/Restricted/Projects/S001 New Anglesey/04 GIS + Models/4.2
Working/4.2.1 Datasets/Boundaries/20170517 Construction Zones
Geopack/20170517_Construction_Zones.gpkg|layername=20170517_Construction_Zones
is not a valid or recognized data source.
2018-11-17T14:53:55 SUCCESS Layer Exported : Successfully saved
vector layer to /home/samw/Restricted/Projects/S001 New Anglesey/04
GIS + Models/4.2 Working/4.2.1 Datasets/Boundaries/20170517
Construction Zones Geopack/20170517_Construction_Zones.gpkg
OGR log:
2018-11-17T14:53:55 WARNING Cannot open
Geopack/20170517_Construction_Zones.gpkg.()
I'm using 3.4.1 on Ubuntu 18.04:
QGIS version: 3.4.1-Madeira
QGIS code revision: 383851c
Compiled against Qt: 5.9.5
Running against Qt: 5.9.5
Compiled against GDAL/OGR: 2.2.3
Running against GDAL/OGR: 2.2.3
Compiled against GEOS: 3.6.2-CAPI-1.10.2
Running against GEOS: 3.6.2-CAPI-1.10.2 4d2925d6
PostgreSQL Client Version: 10.3 (Ubuntu 10.3-1)
SpatiaLite Version: 4.3.0a
QWT Version: 6.1.3
QScintilla2 Version: 2.10.2
PROJ.4 Version: 493
Kind regards,
Sam.
