[Qgis-user] Node Tool - proposing improvements
Antongeo76 antoviscomi at gmail.com
Wed Nov 28 00:59:29 PST 2018
Saber Razmjooei wrote
> I agree with Bernhard. Last time, it was done through QEP and no real
> feedback from users. The change to the node tool behaviour requires input
> from experienced users who do digitizing in their day-to-day works. I
> suggest to have the draft proposal as a blog post on QGIS.org to get more
> users involved in the way forward.
> Currently, there are some bugs and several contradicting preferences and
> requests. Any new changes to the current behaviour without consulting with
> users will probably take us back to square one.
> Regards
> Saber
> On Tue, 27 Nov 2018, 06:51 Bernhard Ströbl <
> bernhard.stroebl@
>  wrote:
> > Hi Nyall,
>> the reason to post this issue to the users' list was to get feedback
>> from users (and developers, too). I am totally aware that a QEP would be
>> appropriate but I doubt that many users are taking part in the
>> discussion there.
>> Anyways I am going to sum up the results and create a proposal later on,
>> will that do?
>> Bernhard
>> Am 27.11.2018 um 01:23 schrieb Nyall Dawson:
>> > On Mon, 26 Nov 2018 at 21:39, Bernhard Ströbl <
> bernhard.stroebl@
>> wrote:
>> >> Dear all,
>> >> I want to apologize, this has become an extremely long mail...
>> >> A lot of discussion has been going on about the recent
>> reimplementation
>> >> of the node tool in QGIS 3.
>> > Hi Bernhard,
>> > Thanks for the detailed proposal, and for taking the time to come up
>> > with a constructive way forward here.
>> > Can I encourage you to copy the contents of your proposal across to
>> > the "QEP" repository:
>> > https://github.com/qgis/QGIS-Enhancement-Proposals/issues ? I think
>> > that's the correct channel to discuss these ideas so that the
>> > conversation is kept central and recorded permanently for reference.
>> > Nyall
>> >> I see two reasons for this:
>> >> 1) The way the tool works is very different from the way it used to
>> work
>> >> in QGIS 2:
>> >> a) in QGIS 2 it was choose feature - choose node(s) - do something
>> >> whereas in QGIS 3 it is choose node - do something
>> >> b) to move a node was click - (keep pressed) - move - release which
>> was
>> >> changed to click - release - move - click - release
>> >> 2) There have been several bugs (as could be expected with a new
>> >> implementation). These, however, were used to question the whole
>> feature
>> >> (most of the bugs are fixed now).
>> >> Apart from bugs and people not being used to the new tool the critics
>> >> concentrate around:
>> >> 1) Probably most annoying: Mouse movements for choosing an existing
>> >> vertex/adding a new vertex at the middle of the line are not well
>> >> defined (especially important if features and its vertices are very
>> >> close together). Imagine a polygon surrounded (or even worse:
>> >> overlapped) by others, now try to click a particular vertex. You will
>> >> fail if always the neighbouring polygon is highlighted. The workaround
>> >> is to select the vertex with a mouse window while its feature is
>> >> highlighted (or previously select the feature e.g. with the
>> >> Select-Feature tool). For overlapping features it is even harder.
>> >> 2) Highlighting effect is disturbing.
>> >> 3) Adding a new vertex puts the new vertex on the mouse ready to be
>> >> moved but user has no intention to move it but to leave it where it
>> has
>> >> been added (e.g. for topological reasons).
>> >> 4) Vertices are not visible all the time but only when the feature is
>> >> highlighted. This can make choosing a particular vertex difficult (see
>> >> also 1).
>> >> 5) It is easy to accidentally add or move a vertex because the most
>> >> intuitive way of selecting something is to click it. But when you
>> click
>> >> a vertex/segment/cross while being highlighted you are already on your
>> >> way to move it.
>> >> 6) The behaviour is not consistent:
>> >> a) If you want to move _one_ vertex, try to grab it when it is
>> >> highlighted then move it; if you want to move several vertices, first
>> >> select them, then click them, then move them.
>> >> b) If you want to delete a vertex, try to grab it when it is
>> >> highlighted; if you want to delete a segment, do not try to grab it
>> when
>> >> it is highlighted but select its two vertices and delete them.
>> >> The German user group thinks that the points raised above are valid,
>> >> even if all pending bugs are fixed. The node tool is still not perfect
>> >> (it wasn't in QGIS 2 either).
>> >> So we propose a change in the way the node tool works and would like
>> to
>> >> hear other users' s opinions.
>> >> While the click - move - click change has valid reasons (use advance
>> >> digitizing panel, pan or zoom map while moving vertices) the dropping
>> of
>> >> the first choose feature - then choose vertex workflow to immediately
>> >> move a vertex has no real reasoning (except that it is less clicks in
>> >> those cases where the node can be easily grabbed in the first place).
>> >> But this new workflow is the main cause for the problems listed above.
>> >> Therefore we would like to see the old workflow reimplemented with
>> some
>> >> of the new ideas added plus some new ingredients. This is the draft
>> for
>> >> how the tool might work in the future:
>> >> 1) While the mouse is moved around features are highlighted to
>> indicate
>> >> they can be edited. Furthermore eventual vertices, segments or crosses
>> >> are highlighted, too (as in QGIS 3).
>> >> 2) While a feature is being highlighted, it can be chosen with a left
>> >> click (new).
>> >> 3) If the user makes a right click instead, another (adjacent) feature
>> >> is highlighted and can be chosen with a subsequent left click and so
>> on
>> >> (new).
>> >> 4) As soon as a feature is chosen, the Vertex-Editor panel is opened
>> (as
>> >> in QGIS 2).
>> >> 5) A chosen feature is the only feature whose vertices can be edited
>> at
>> >> that point* (as in QGIS 2). The chosen feature and all its vertices
>> stay
>> >> visible until the end of this feature's editing session (as in QGIS
>> 2).
>> >> If a vertex was highlighted it is immediately selected, if a segment
>> was
>> >> highlighted, its two vertices are immediately selected, if the middle
>> of
>> >> a segment was highlighted with a cross a new vertex is created there
>> and
>> >> immediately selected (new).
>> >> 6) A vertex is selected by left clicking on it (as in QGIS 2).
>> >> 7) Several vertices are selected by using a mouse window (as in QGIS 2
>> >> and 3).
>> >> 8) A click on a segment selects its two vertices (as in QGIS 2).
>> >> 9) Vertices can be selected via the Vertex-Editor panel, too (as was
>> in
>> >> QGIS 2)
>> >> 10) Every new vertex selection clears any previuos selection except if
>> >> Crtl is pressed which adds the new selection to the current if
>> vertices
>> >> were not selected or subtracts them from the current selection if they
>> >> were selected (as in QGIS 2).
>> >> 11) Selected vertices can be deleted (as in QGIS 2 and 3).
>> >> 12) Selected vertices can be moved by clicking either of them, thus
>> the
>> >> vertex (the vertices) are attached to the mouse and can be dropped
>> with
>> >> another left click (as in QGIS 3). A right click aborts the moving
>> >> operation but the vertices are still selected (new).
>> >> 13) A new vertex can be created by double clicking on any segment (as
>> in
>> >> QGIS 2 and 3), the new vertex is immediately selected (new).
>> >> 14) A right click ends the chosen feature's editing session, if
>> another
>> >> feature is within reach it is immediately highlighted, continue as in
>> 1)
>> >> (new).
>> >> 14b) To be discussed: Left clicking another feature immediately
>> chooses
>> >> this feature (as in QGIS 2).
>> >> * topological editing is still posssible, of course
>> >> We see the following advantages in this approach:
>> >> 1) The new quick editing possibilities are preserved, there is just
>> one
>> >> additional click (compared to current QGIS 3) to move an existing
>> vertex
>> >> or segment or to create and immediately move a new vertex.
>> >> 2) It is easier to create a new vertex in place.
>> >> 3) It is a lot easier to graphically choose the feature to edit.
>> >> 4) The highlighting indicates, which feature will be chosen by an
>> >> immediate click, no surprises for the user.
>> >> 5) It is easier to graphically select the vertices to edit.
>> >> 6) The workflow is always the same: Choose feature - select vertices -
>> >> do something with them.
>> >> 7) The workflow is consistent with creating a new feature (right click
>> >> to finish editing).
>> >> 8) The application is more consistent because graphically selecting
>> >> vertices works the exact same way as graphically selecting features
>> with
>> >> the Select-features tool.
>> >> I appreciate your feedback
>> >> Bernhard
>> >> __________ Information from ESET Mail Security, version of virus
>> signature database 18443 (20181126) __________
>> >> The message was checked by ESET Mail Security.
>> >> http://www.eset.com
>> >> _______________________________________________
>> >> Qgis-user mailing list
> Qgis-user at .osgeo
>> >> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> >> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> signature database 18446 (20181126) __________
>> > http://www.eset.com
>> Bernhard Ströbl
>> Anwendungsbetreuer GIS
>> Kommunale Immobilien Jena
>> Am Anger 26
>> 07743 Jena
>> Tel.: 03641 49- 5190
>> E-Mail:
> bernhard.stroebl@
>> Internet: www.kij.de
>> Eigenbetrieb der Stadt Jena
>> Werkleiter: Karl-Hermann Kliewe
>> signature
>> database 18447 (20181127) __________
>> http://www.eset.com
> Qgis-user at .osgeo
> Qgis-user at .osgeo
Hi Saber,
the discussion on node tool seems like a fight against windmills,
where few users raise doubts about the actual improvement of the node tool
making them look like isolated cases or local and private matters.
I agree with you even if it seems that there are few users interested in the
subject in this mailing list I among others I tried to expose my concerns in
QEP but I have not any feedback.
I think there is a big gap between the development of this very important
part and the end users!
Then I would suggest the following
could you create a survey directly at the opening of QGIS?
For example a link (maybe in the welcome dialog) to a dedicated forum that
gives the possibility to ask users what they believe is better to speed up
and optimize node tool or other features in QGIS.
Many of the users are not subscribed to the mailing list and don't even know
that there is a mailing list!
We should find a more incisive way to publicize the possible interactions
between users and developers
Greetings
Antonio
Antonio
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
