[Qgis-user] Very Slow Table Operations in QGIS 3.2.3
Luigi Pirelli
luipir at gmail.com
Wed Oct 3 11:43:37 PDT 2018
can you test doing operations with field calculator without having the
attribute table opened? just a workaround could be to use a virtual layer
then save the entire layer later.
Luigi Pirelli
* LinkedIn: https://www.linkedin.com/in/luigipirelli
* Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
* GitHub: https://github.com/luipir
* Mastering QGIS 2nd Edition:
https://www.packtpub.com/big-data-and-business-intelligence/mastering-qgis-second-edition
* Hire me: http://goo.gl/BYRQKg
On Wed, 3 Oct 2018 at 18:11, Kelley Jabr <kjabr at indeed.com> wrote:
> Hello,
> I'm working with a geopackage on ~530k features, and just about everything
> I try to do in the table takes way longer than expected.
> - Adding a field took 5 minutes (table now has 22 total fields, so not
> massive)
> - Field Calculator on ~32k selected records took 8 minutes (literally
> all I was putting in the cells was: N)
> - Field calculator on ~480k records took so many hours that I had to
> leave it running over the weekend and when I came back, the Field
> Calculator had "closed unexpectedly"
> (I'm running on a linux machine with an Intel Core i7 and 32GB of memory.)
> Has anyone else experience similar issues? Any advice or recommendations
> for how to improve performance here?
> Thank you,
> Kelley Jabr
> Analyst, Geographic Data Operations
> kjabr at indeed.com
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20181003/a08c477d/attachment.html>
