[Qgis-user] Very Slow Table Operations in QGIS 3.2.3
Andreas Neumann
a.neumann at carto.net
Wed Oct 3 12:31:29 PDT 2018
Glad to hear that it helped to run the operations on a closed table.
Nevertheless, as Luigi said, it would make sense to submit an issue
report about this slowness.
The other thing one has to keep on mind:
The SQLite API is kind of limited. Only until recently, if you wanted to
rename a field, one had to copy the whole table with the renamed field
changed in the new table - then the old table had to be removed (all in
the background), because there was API to rename columns in SQLite. I
think with the very recent version, which is not rolled out into most
OS, this has changed. You'd also need a very recent GDAL/OGR.
Greetings,
Andreas
Am 03.10.2018 um 21:20 schrieb Kelley Jabr:
> Luigi, I'm pretty sure you just solved my problem. I tried a few
> operations with the table closed and it was like night and day. That
> 400k field calculator finished in mere moments! Thank you!!
> On Wed, Oct 3, 2018 at 1:42 PM Luigi Pirelli <luipir at gmail.com
> <mailto:luipir at gmail.com>> wrote:
> can you test doing operations with field calculator without having
> the attribute table opened? just a workaround could be to use a
> virtual layer then save the entire layer later.
> Luigi Pirelli
> * LinkedIn: https://www.linkedin.com/in/luigipirelli
> * Stackexchange:
> http://gis.stackexchange.com/users/19667/luigi-pirelli
> * GitHub: https://github.com/luipir
> * Mastering QGIS 2nd Edition:
> https://www.packtpub.com/big-data-and-business-intelligence/mastering-qgis-second-edition
> * Hire me: http://goo.gl/BYRQKg
> On Wed, 3 Oct 2018 at 18:11, Kelley Jabr <kjabr at indeed.com
> <mailto:kjabr at indeed.com>> wrote:
> Hello,
> I'm working with a geopackage on ~530k features, and just
> about everything I try to do in the table takes way longer
> than expected.
> * Adding a field took 5 minutes (table now has 22 total
> fields, so not massive)
> * Field Calculator on ~32k selected records took 8 minutes
> (literally all I was putting in the cells was: N)
> * Field calculator on ~480k records took so many hours that
> I had to leave it running over the weekend and when I came
> back, the Field Calculator had "closed unexpectedly"
> (I'm running on a linux machine with an Intel Core i7 and 32GB
> of memory.)
> Has anyone else experience similar issues? Any advice or
> recommendations for how to improve performance here?
> Thank you,
> Kelley Jabr
> Analyst, Geographic Data Operations
> kjabr at indeed.com <mailto:kjabr at indeed.com>
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> Kelley Jabr
> Indeed- We help people get jobs.
> Indeed.com <http://www.indeed.com>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20181003/ab31d431/attachment.html>
