[Qgis-user] Very Slow Table Operations in QGIS 3.2.3
Kelley Jabr
kjabr at indeed.com
Wed Oct 3 13:40:04 PDT 2018
Okay, I've created an issue for this situation. Hopefully I've done it
satisfactorily. Thanks again!
On Wed, Oct 3, 2018 at 2:31 PM Andreas Neumann <a.neumann at carto.net> wrote:
> Hi,
> Glad to hear that it helped to run the operations on a closed table.
> Nevertheless, as Luigi said, it would make sense to submit an issue report
> about this slowness.
> The other thing one has to keep on mind:
> The SQLite API is kind of limited. Only until recently, if you wanted to
> rename a field, one had to copy the whole table with the renamed field
> changed in the new table - then the old table had to be removed (all in the
> background), because there was API to rename columns in SQLite. I think
> with the very recent version, which is not rolled out into most OS, this
> has changed. You'd also need a very recent GDAL/OGR.
> Greetings,
> Andreas
> Am 03.10.2018 um 21:20 schrieb Kelley Jabr:
> Luigi, I'm pretty sure you just solved my problem. I tried a few
> operations with the table closed and it was like night and day. That 400k
> field calculator finished in mere moments! Thank you!!
> On Wed, Oct 3, 2018 at 1:42 PM Luigi Pirelli <luipir at gmail.com> wrote:
>> can you test doing operations with field calculator without having the
>> attribute table opened? just a workaround could be to use a virtual layer
>> then save the entire layer later.
>> Luigi Pirelli
>> * LinkedIn: https://www.linkedin.com/in/luigipirelli
>> * Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
>> * GitHub: https://github.com/luipir
>> * Mastering QGIS 2nd Edition:
>> https://www.packtpub.com/big-data-and-business-intelligence/mastering-qgis-second-edition
>> * Hire me: http://goo.gl/BYRQKg
>> On Wed, 3 Oct 2018 at 18:11, Kelley Jabr <kjabr at indeed.com> wrote:
>>> Hello,
>>> I'm working with a geopackage on ~530k features, and just about
>>> everything I try to do in the table takes way longer than expected.
>>> - Adding a field took 5 minutes (table now has 22 total fields, so
>>> not massive)
>>> - Field Calculator on ~32k selected records took 8 minutes
>>> (literally all I was putting in the cells was: N)
>>> - Field calculator on ~480k records took so many hours that I had to
>>> leave it running over the weekend and when I came back, the Field
>>> Calculator had "closed unexpectedly"
>>> (I'm running on a linux machine with an Intel Core i7 and 32GB of
>>> memory.)
>>> Has anyone else experience similar issues? Any advice or recommendations
>>> for how to improve performance here?
>>> Thank you,
>>> Kelley Jabr
>>> Analyst, Geographic Data Operations
>>> kjabr at indeed.com
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Kelley Jabr
> kjabr at indeed.com
> Indeed - We help people get jobs.
> Indeed.com <http://www.indeed.com>
> Qgis-user mailing listQgis-user at lists.osgeo.org
Kelley Jabr
kjabr at indeed.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20181003/2c54a49e/attachment-0001.html>
