[Qgis-user] Select poligons related to a point layer
Mithoefer
mithoefer at gbd-consult.de
Thu Oct 4 04:45:02 PDT 2018
Hello Henrique,
you can also use the spatiajoin plugin (create temprary join) or nnjoin
to join and select data.
Kind regard
Klaus Mithöfer
Mit freundlichen Grüßen
Klaus Mithöfer
Geoinformatikbüro Dassau GmbH
Rethelstrasse 153
D - 40237 Düsseldorf
Tel: +49-1573-7514549
http://www.gbd-consult.de
Registergericht: Amtsgericht Düsseldorf, HR B 74022
Geschäftsführer: Otto Dassau
Am 04.10.2018 um 12:42 schrieb Henrique Duarte Vieira:
> Hello to all,
> I call your help for the following task:
> I have a point layer, in which each point represents a company that
> operates in several municipalities listed in its table of properties
> (points are located at companies headquarters) .
> Additionally, I have a polygon layer with all the municipalities.
> What I'm trying to do is to click over each company (point layer) and
> automatically select all the municipalities (polygon layer) in witch
> that specific company operates.
> Could someone give me a clue about how to perform this selection?
> Thanks in advance for you contributions, best Regards.
> */Henrique Duarte Vieira/*
> (henrq.duarte at gmail.com <mailto:henrq.duarte at gmail.com>)
> Qgis-user mailing list
