[Qgis-user] Potential Bug in writing gpkg from database manager?
Michael Treglia mtreglia at gmail.com
Fri Oct 5 13:01:09 PDT 2018
Whoops! Forgot the key information:
(Running on Windows 7 Pro x64)
QGIS version
3.2.3-Bonn
QGIS code revision
9b176802e5 <https://github.com/qgis/QGIS/commit/9b176802e5>
Compiled against Qt
5.9.2
Running against Qt
5.9.2
Compiled against GDAL/OGR
2.2.4
Running against GDAL/OGR
2.2.4
Compiled against GEOS
3.6.1-CAPI-1.10.1
Running against GEOS
3.6.1-CAPI-1.10.1 r0
PostgreSQL Client Version
9.2.4
SpatiaLite Version
4.3.0
QWT Version
6.1.3
QScintilla2 Version
2.10.1
PROJ.4 Version
493
On Fri, Oct 5, 2018 at 4:00 PM Michael Treglia <mtreglia at gmail.com> wrote:
> Hi All,
> Just checking if others are observing something similar:
> * I was writing data to gpkg files from a postgis database.from the
> Database Manager. (e.g., select a layer from the PostGIS database and hit
> the "export to file" button at the top.
> * The resulting gpkg layer loses data in a column towards the left, but
> all of the headings are maintained. Thus, data are shifted to the left one
> column from a certain point on, and the last column has NULLs.
> If writing into an existing gpkg file, dragging and dropping the layer
> from the PostGIS db into the gpkg file and selecting appropriate options in
> the dialogue box that pops up does not have that issue.
> I'm still trying to see exactly what's going on, but figured I'd see if
> this is something others are experiencing (or if it's already been
> reported).
> Mike
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20181005/1dff3231/attachment.html>
