[Qgis-user] Potential Bug in writing gpkg from database manager?
Michael Treglia mtreglia at gmail.com
Fri Oct 5 13:14:43 PDT 2018
Just to clarify, if installing via OSGeo4w, use QGIS-Dev: QGIS Nightly
build of the development branch (3.3.0-88)?
On Fri, Oct 5, 2018 at 4:08 PM Luigi Pirelli <luipir at gmail.com> wrote:
> may you check with master? 3.2 is at end of life.
> tnx
> Luigi Pirelli
> * LinkedIn: https://www.linkedin.com/in/luigipirelli
> * Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
> * GitHub: https://github.com/luipir
> * Mastering QGIS 2nd Edition:
> https://www.packtpub.com/big-data-and-business-intelligence/mastering-qgis-second-edition
> * Hire me: http://goo.gl/BYRQKg
> On Fri, 5 Oct 2018 at 21:59, Michael Treglia <mtreglia at gmail.com> wrote:
>> Whoops! Forgot the key information:
>> (Running on Windows 7 Pro x64)
>> QGIS version
>> 3.2.3-Bonn
>> QGIS code revision
>> 9b176802e5 <https://github.com/qgis/QGIS/commit/9b176802e5>
>> Compiled against Qt
>> 5.9.2
>> Running against Qt
>> 5.9.2
>> Compiled against GDAL/OGR
>> 2.2.4
>> Running against GDAL/OGR
>> 2.2.4
>> Compiled against GEOS
>> 3.6.1-CAPI-1.10.1
>> Running against GEOS
>> 3.6.1-CAPI-1.10.1 r0
>> PostgreSQL Client Version
>> 9.2.4
>> SpatiaLite Version
>> 4.3.0
>> QWT Version
>> 6.1.3
>> QScintilla2 Version
>> 2.10.1
>> PROJ.4 Version
>> 493
>> On Fri, Oct 5, 2018 at 4:00 PM Michael Treglia <mtreglia at gmail.com>
>> wrote:
>>> Hi All,
>>> Just checking if others are observing something similar:
>>> * I was writing data to gpkg files from a postgis database.from the
>>> Database Manager. (e.g., select a layer from the PostGIS database and hit
>>> the "export to file" button at the top.
>>> * The resulting gpkg layer loses data in a column towards the left, but
>>> all of the headings are maintained. Thus, data are shifted to the left one
>>> column from a certain point on, and the last column has NULLs.
>>> If writing into an existing gpkg file, dragging and dropping the layer
>>> from the PostGIS db into the gpkg file and selecting appropriate options in
>>> the dialogue box that pops up does not have that issue.
>>> I'm still trying to see exactly what's going on, but figured I'd see if
>>> this is something others are experiencing (or if it's already been
>>> reported).
>>> Mike
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20181005/058a532f/attachment.html>
