[Qgis-user] Potential Bug in writing gpkg from database manager?
Luigi Pirelli
luipir at gmail.com
Fri Oct 5 13:18:15 PDT 2018
exactly
Luigi Pirelli
* LinkedIn: https://www.linkedin.com/in/luigipirelli
* Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
* GitHub: https://github.com/luipir
* Mastering QGIS 2nd Edition:
https://www.packtpub.com/big-data-and-business-intelligence/mastering-qgis-second-edition
* Hire me: http://goo.gl/BYRQKg
On Fri, 5 Oct 2018 at 22:12, Michael Treglia <mtreglia at gmail.com> wrote:
> Just to clarify, if installing via OSGeo4w, use QGIS-Dev: QGIS Nightly
> build of the development branch (3.3.0-88)?
> On Fri, Oct 5, 2018 at 4:08 PM Luigi Pirelli <luipir at gmail.com> wrote:
>> may you check with master? 3.2 is at end of life.
>> tnx
>> Luigi Pirelli
>> On Fri, 5 Oct 2018 at 21:59, Michael Treglia <mtreglia at gmail.com> wrote:
>>> Whoops! Forgot the key information:
>>> (Running on Windows 7 Pro x64)
>>> QGIS version
>>> 3.2.3-Bonn
>>> QGIS code revision
>>> 9b176802e5 <https://github.com/qgis/QGIS/commit/9b176802e5>
>>> Compiled against Qt
>>> 5.9.2
>>> Running against Qt
>>> 5.9.2
>>> Compiled against GDAL/OGR
>>> 2.2.4
>>> Running against GDAL/OGR
>>> 2.2.4
>>> Compiled against GEOS
>>> 3.6.1-CAPI-1.10.1
>>> Running against GEOS
>>> 3.6.1-CAPI-1.10.1 r0
>>> PostgreSQL Client Version
>>> 9.2.4
>>> SpatiaLite Version
>>> 4.3.0
>>> QWT Version
>>> 6.1.3
>>> QScintilla2 Version
>>> 2.10.1
>>> PROJ.4 Version
>>> 493
>>> On Fri, Oct 5, 2018 at 4:00 PM Michael Treglia <mtreglia at gmail.com>
>>> wrote:
>>>> Hi All,
>>>> Just checking if others are observing something similar:
>>>> * I was writing data to gpkg files from a postgis database.from the
>>>> Database Manager. (e.g., select a layer from the PostGIS database and hit
>>>> the "export to file" button at the top.
>>>> * The resulting gpkg layer loses data in a column towards the left, but
>>>> all of the headings are maintained. Thus, data are shifted to the left one
>>>> column from a certain point on, and the last column has NULLs.
>>>> If writing into an existing gpkg file, dragging and dropping the layer
>>>> from the PostGIS db into the gpkg file and selecting appropriate options in
>>>> the dialogue box that pops up does not have that issue.
>>>> I'm still trying to see exactly what's going on, but figured I'd see if
>>>> this is something others are experiencing (or if it's already been
>>>> reported).
>>>> Mike
>>>> _______________________________________________
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20181005/680f61d4/attachment-0001.html>
