[Qgis-user] Cannot downgrade plugin
    Andre Joost
    andre+joost at nurfuerspam.de
    Wed Oct 10 07:56:23 PDT 2018
Am 10.10.18 um 14:40 schrieb Tyler Veinot:
> I am using GISwater, a QGIS plugin for water and sewer networks, and I
> decided to try the 3.1 development version and decided to roll back to 2.1.
> The rollback for the software and database worked fine but when I try to
> install the 2.1 plugin qgis keeps installing the 3.1 plugin. The 2 plugins
> have 2 different repositories and even when I delete the 3.1 repo qgis
> still installs the 3.1 plugin giving me a warning that my version is higher
> than the repos. Downgrade wont work either. How can I get rid of whatever
> is holding qgis to that plugin?
> Tyler
> 3.1 Repo https://download.giswater.org/plugin/3.1/giswater.xml
> 2.1 Repo https://download.giswater.org/plugin/giswater.xml
The last link should be
https://download.giswater.org/plugin/2.1/giswater.xml
As far as I can see, it is a zip file which has to be expanded in the
right folder of your C:/users/username/.qgis2/python/plugins folder.
Make sure you don't have the 3.1 version there anymore.
HTH,
Andre Joost
