[Qgis-user] QuickOSM not downloading data
Etienne Trimaille etienne.trimaille at gmail.com
Fri Oct 12 05:59:13 PDT 2018
As a temporary workaround, after you executed your query, go in your
temporary folder (/tmp on linux) and open manually the latest OSM file
provided.
Le ven. 12 oct. 2018 à 07:52, Etienne Trimaille <etienne.trimaille at gmail.com>
a écrit :
> Hi Matteo,
> I noticed the issue too.
> With QGIS 3.2, no problem, QuickOSM is working well.
> With QGIS 3.3, not working since 1 week. But QuickOSM is not failling in
> its processing, no python error. The plugin raises a warning if no OSM
> object are found, but this is not the case, no warnings. So it means that
> the plugin could download and parse some features. But at the end of the
> process, layers are empty. The same plugin version is working on 3.2 and on
> master a few weeks ago.
> Le ven. 12 oct. 2018 à 03:38, matteo <matteo.ghetta at gmail.com> a écrit :
>> Hi all,
>> I'm noticing that the awesome QuickOSM plugin is not downloading data
>> anymore.
>> I just have a XYZ OSM tile loaded (CRS 3857) and the latest QuickOSM
>> release for QGIS 3.3 (same thing happens with QGIS 3.2).
>> I tried different queries (natural -> peak, in an area where a lot of
>> peaks are shown on OSM map, etc).
>> Some other user is experiencing the same problem?
>> Thanks and cheers
>> Matteo
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20181012/b2245227/attachment.html>
