[Qgis-user] Network access is disabled
    Jorge Gustavo Rocha
    jgr at di.uminho.pt
    Mon Oct 15 03:10:41 PDT 2018
Hi Kristian,
Check the settings at: Settings → Options → Network
These are the settings used for http access.
Have you any proxy on your network for http access?
Regards,
Jorge
Às 10:48 de 15/10/2018, Kristian Evers escreveu:
> Hi,
> I am having some issues adding WMS layers. QGIS fails to retrieve the
> capabilities
> file and adds “Network access is disabled” to the log. This is with QGIS
> 3.2.3 on Win10.
> Googling a bit I see that a few others have experienced this in the
> past, although
> with earlier versions of QGIS3. As far as I can see there isn’t any
> obvious ways
> where network access can be disabled within QGIS. Outside QGIS there are no
> problems accessing the network. QGIS doesn’t have problems reading files
> from
> network drives either, so this seems to be purely related to HTTP-access.
> Is this a known issue? If so, is there a workaround?
> Best regards,
> Kristian
> Qgis-user mailing list
J. Gustavo
Jorge Gustavo Rocha
Departamento de Informática
Universidade do Minho
4710-057 Braga
Tel: +351 253604480
Fax: +351 253604471
Móvel: +351 910333888
skype: nabocudnosor
