[Qgis-user] Network access is disabled
    Luigi Pirelli
    luipir at gmail.com
    Mon Oct 15 03:15:55 PDT 2018
I faced this problem with a strudent... my investigation revealed that
there were a esoteric combination among win service pack, qt version and
compiler version that give this effect. My only suggestion is to update
your OS and/or lates qgis version (with updated qt) and see if something
change.
I should say that it is a kind of problem that are almost impossible to
solve, btw I hope someone have more hints.
IIRC the problem was reated with qt component that listen about the wifi
signal availabaility (ther are qt tiket open about this)... I asked to the
student to (in order)
1) try with ethernet
2) update OS with laster service pack
3) use master
I dind't have any feedback from that student :(
cheers
Luigi Pirelli
* LinkedIn: https://www.linkedin.com/in/luigipirelli
* Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
* GitHub: https://github.com/luipir
* Mastering QGIS 2nd Edition:
https://www.packtpub.com/big-data-and-business-intelligence/mastering-qgis-second-edition
* Hire me: http://goo.gl/BYRQKg
On Mon, 15 Oct 2018 at 11:49, Kristian Evers <kreve at sdfe.dk> wrote:
> Hi,
> I am having some issues adding WMS layers. QGIS fails to retrieve the
> capabilities
> file and adds “Network access is disabled” to the log. This is with QGIS
> 3.2.3 on Win10.
> Googling a bit I see that a few others have experienced this in the past,
> although
> with earlier versions of QGIS3. As far as I can see there isn’t any
> obvious ways
> where network access can be disabled within QGIS. Outside QGIS there are no
> problems accessing the network. QGIS doesn’t have problems reading files
> from
> network drives either, so this seems to be purely related to HTTP-access.
> Is this a known issue? If so, is there a workaround?
> Best regards,
> Kristian
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20181015/ec6b5c72/attachment.html>
