[Qgis-user] Network access is disabled
Kristian Evers
kreve at sdfe.dk
Tue Oct 16 11:49:11 PDT 2018
All,
Just a quick follow up on this. The kinks with the updated
OSGeo4W packages was swiftly ironed out and updating
everything to the latest version fixed my problem. Hopefully
this is fixed for good.
Thanks to Jürgen for quickly updating the packages that
had problems.
/Kristian
On 15 Oct 2018, at 12:51, Kristian Evers <kreve at sdfe.dk<mailto:kreve at sdfe.dk>> wrote:
Jorge,
> Check the settings at: Settings → Options → Network
> These are the settings used for http access.
> Have you any proxy on your network for http access?
No proxy here. The same settings work on several tens of
other computers in the building.
Luigi,
Thanks for sharing your experiences. I had a hunch
something like that was to blame. I am hoping that
Jürgens recent updates to the whole OSGeo4W stack
will sort this issue out. But first there’s a few kinks
with those updates that needs sorting out.
/Kristian
Fra: Luigi Pirelli <luipir at gmail.com<mailto:luipir at gmail.com>>
Sendt: 15. oktober 2018 12:16
Til: Kristian Evers <kreve at sdfe.dk<mailto:kreve at sdfe.dk>>
Cc: qgis-user ML <qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>>
Emne: Re: [Qgis-user] Network access is disabled
I faced this problem with a strudent... my investigation revealed that there were a esoteric combination among win service pack, qt version and compiler version that give this effect. My only suggestion is to update your OS and/or lates qgis version (with updated qt) and see if something change.
I should say that it is a kind of problem that are almost impossible to solve, btw I hope someone have more hints.
IIRC the problem was reated with qt component that listen about the wifi signal availabaility (ther are qt tiket open about this)... I asked to the student to (in order)
1) try with ethernet
2) update OS with laster service pack
3) use master
I dind't have any feedback from that student :(
cheers
Luigi Pirelli
* LinkedIn: https://www.linkedin.com/in/luigipirelli
* Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
* GitHub: https://github.com/luipir
* Mastering QGIS 2nd Edition:
* https://www.packtpub.com/big-data-and-business-intelligence/mastering-qgis-second-edition
* Hire me: http://goo.gl/BYRQKg
On Mon, 15 Oct 2018 at 11:49, Kristian Evers <kreve at sdfe.dk<mailto:kreve at sdfe.dk>> wrote:
I am having some issues adding WMS layers. QGIS fails to retrieve the capabilities
file and adds “Network access is disabled” to the log. This is with QGIS 3.2.3 on Win10.
Googling a bit I see that a few others have experienced this in the past, although
with earlier versions of QGIS3. As far as I can see there isn’t any obvious ways
where network access can be disabled within QGIS. Outside QGIS there are no
problems accessing the network. QGIS doesn’t have problems reading files from
network drives either, so this seems to be purely related to HTTP-access.
Is this a known issue? If so, is there a workaround?
Best regards,
Kristian
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20181016/42220267/attachment.html>
