[Qgis-user] Network access is disabled
Luigi Pirelli luipir at gmail.com
Tue Oct 16 12:28:18 PDT 2018
great, tnx Jürgen
Luigi Pirelli
* LinkedIn: https://www.linkedin.com/in/luigipirelli
* Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
* GitHub: https://github.com/luipir
* Mastering QGIS 2nd Edition:
https://www.packtpub.com/big-data-and-business-intelligence/mastering-qgis-second-edition
* Hire me: http://goo.gl/BYRQKg
On Tue, 16 Oct 2018 at 20:49, Kristian Evers <kreve at sdfe.dk> wrote:
> All,
> Just a quick follow up on this. The kinks with the updated
> OSGeo4W packages was swiftly ironed out and updating
> everything to the latest version fixed my problem. Hopefully
> this is fixed for good.
> Thanks to Jürgen for quickly updating the packages that
> had problems.
> /Kristian
> On 15 Oct 2018, at 12:51, Kristian Evers <kreve at sdfe.dk> wrote:
> Jorge,
> > Check the settings at: Settings → Options → Network
> > These are the settings used for http access.
> > Have you any proxy on your network for http access?
> No proxy here. The same settings work on several tens of
> other computers in the building.
> Luigi,
> Thanks for sharing your experiences. I had a hunch
> something like that was to blame.  I am hoping that
> Jürgens recent updates to the whole OSGeo4W stack
> will sort this issue out. But first there’s a few kinks
> with those updates that needs sorting out.
> /Kristian
> *Fra:* Luigi Pirelli <luipir at gmail.com>
> *Sendt:* 15. oktober 2018 12:16
> *Til:* Kristian Evers <kreve at sdfe.dk>
> *Cc:* qgis-user ML <qgis-user at lists.osgeo.org>
> *Emne:* Re: [Qgis-user] Network access is disabled
> I faced this problem with a strudent... my investigation revealed that
> there were a esoteric combination among win service pack, qt version and
> compiler version that give this effect. My only suggestion is to update
> your OS and/or lates qgis version (with updated qt) and see if something
> change.
> I should say that it is a kind of problem that are almost impossible to
> solve, btw I hope someone have more hints.
> IIRC the problem was reated with qt component that listen about the wifi
> signal availabaility (ther are qt tiket open about this)... I asked to the
> student to (in order)
> 1) try with ethernet
> 2) update OS with laster service pack
> 3) use master
> I dind't have any feedback from that student :(
> cheers
> Luigi Pirelli
> On Mon, 15 Oct 2018 at 11:49, Kristian Evers <kreve at sdfe.dk> wrote:
> Hi,
> I am having some issues adding WMS layers. QGIS fails to retrieve the
> capabilities
> file and adds “Network access is disabled” to the log. This is with QGIS
> 3.2.3 on Win10.
> Googling a bit I see that a few others have experienced this in the past,
> although
> with earlier versions of QGIS3. As far as I can see there isn’t any
> obvious ways
> where network access can be disabled within QGIS. Outside QGIS there are no
> problems accessing the network. QGIS doesn’t have problems reading files
> from
> network drives either, so this seems to be purely related to HTTP-access.
> Is this a known issue? If so, is there a workaround?
> Best regards,
> Kristian
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20181016/ce3e3c7a/attachment.html>
