[Qgis-user] OSGeo4W install on Windows Server 2012R2
Winiwarter, Lukas lukas.winiwarter at tuwien.ac.at
Wed Oct 17 01:09:12 PDT 2018
Hi Tyler, Antonio,
I run into the same issue with "zip.dll" when trying to install QGIS
3.2.3-1 or 3.2.3-2 from the network installer on Win10. The error
message reads (in German):
crssync.exe - Systemfehler
Die Ausführung des Codes kann nicht fortgesetzt werden, da zip.dll nicht
gefunden wurde. Durch eine Neuinstallation des Programms kann das
Problem möglicherweise behoben werden.
And after pressing ok on the popup, in the Setup window: qgis-common.bat
exit code -1073741515
However, installing qgis-ltr (2.18) works fine.
best,
Lukas
On 17.10.2018 07:42, Antongeo76 wrote:
> Hi Tyler,
> I'd yesterday I'd trouble with install on windows 7
> Well I find that something wrong QGIS 3.2.3 as QGIS Master
> don't start an come out with a Windows error message referred to absence of
> qgis.dll…
> Well,
> I identified that the conflict were whit
> msvcr110.dll
> msvcp110.dll
> I've unlocked this two dlls and erased them
> Then I've restored them from trash
> I've re-run osgeo setup and all works fine
> I hope this can help you
> Tyler Veinot-2 wrote
>> All;
>> Trying to install QGIS and QGIS Server using Osgeo4W installer on a
>> virtual
>> server running Windows Server 2012R2 and I keep getting an error "This
>> program can't start because zip.dll is missing from your computer. Try
>> reinstalling the program to fix this problem."
>> I don't have a zip.dll anywhere but I cannot find out what package
>> installs
>> it.
>> Anyone else run into this? Any solutions?
>> Thanks;
>> Tyler
>> Qgis-user mailing list
>> Qgis-user at .osgeo
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Antonio
> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
