[Qgis-user] OSGeo4W install on Windows Server 2012R2
Antongeo76 antoviscomi at gmail.com
Wed Oct 17 03:10:59 PDT 2018
Winiwarter, Lukas wrote
> Hi Tyler, Antonio,
> I run into the same issue with "zip.dll" when trying to install QGIS
> 3.2.3-1 or 3.2.3-2 from the network installer on Win10. The error
> message reads (in German):
> crssync.exe - Systemfehler
> Die Ausführung des Codes kann nicht fortgesetzt werden, da zip.dll nicht
> gefunden wurde. Durch eine Neuinstallation des Programms kann das
> Problem möglicherweise behoben werden.
> And after pressing ok on the popup, in the Setup window: qgis-common.bat
> exit code -1073741515
> However, installing qgis-ltr (2.18) works fine.
> best,
> Lukas
> On 17.10.2018 07:42, Antongeo76 wrote:
>> Hi Tyler,
>> I'd yesterday I'd trouble with install on windows 7
>> Well I find that something wrong QGIS 3.2.3 as QGIS Master
>> don't start an come out with a Windows error message referred to absence
>> of
>> qgis.dll…
>> Well,
>> I identified that the conflict were whit
>> msvcr110.dll
>> msvcp110.dll
>> I've unlocked this two dlls and erased them
>> Then I've restored them from trash
>> I've re-run osgeo setup and all works fine
>> I hope this can help you
>> Tyler Veinot-2 wrote
>>> All;
>>> Trying to install QGIS and QGIS Server using Osgeo4W installer on a
>>> virtual
>>> server running Windows Server 2012R2 and I keep getting an error "This
>>> program can't start because zip.dll is missing from your computer. Try
>>> reinstalling the program to fix this problem."
>>> I don't have a zip.dll anywhere but I cannot find out what package
>>> installs
>>> it.
>>> Anyone else run into this? Any solutions?
>>> Thanks;
>>> Tyler
>>> Qgis-user mailing list
>>> Qgis-user at .osgeo
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Antonio
>> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
> Qgis-user at .osgeo
> Qgis-user at .osgeo
Hi Lukas,
It is the same error I read in my insallation Yesterday,
If you unlock and Erase-restore the files msvcr and msvcp from
c:/Windows/system32, then you reinstall from osgeo all works fine
Regards
Antonio
Antonio
