[Qgis-user] OSGeo4W install on Windows Server 2012R2
Tyler Veinot tylerkveinot at gmail.com
Wed Oct 17 08:16:40 PDT 2018
All;
Thanks it is working now
Tyler
On Wed, Oct 17, 2018 at 7:11 AM Antongeo76 <antoviscomi at gmail.com> wrote:
> Winiwarter, Lukas wrote
> > Hi Tyler, Antonio,
> > I run into the same issue with "zip.dll" when trying to install QGIS
> > 3.2.3-1 or 3.2.3-2 from the network installer on Win10. The error
> > message reads (in German):
> > crssync.exe - Systemfehler
> > Die Ausführung des Codes kann nicht fortgesetzt werden, da zip.dll nicht
> > gefunden wurde. Durch eine Neuinstallation des Programms kann das
> > Problem möglicherweise behoben werden.
> > And after pressing ok on the popup, in the Setup window: qgis-common.bat
> > exit code -1073741515
> > However, installing qgis-ltr (2.18) works fine.
> > best,
> > Lukas
> > On 17.10.2018 07:42, Antongeo76 wrote:
> >> Hi Tyler,
> >> I'd yesterday I'd trouble with install on windows 7
> >> Well I find that something wrong QGIS 3.2.3 as QGIS Master
> >> don't start an come out with a Windows error message referred to absence
> >> of
> >> qgis.dll…
> >> Well,
> >> I identified that the conflict were whit
> >> msvcr110.dll
> >> msvcp110.dll
> >> I've unlocked this two dlls and erased them
> >> Then I've restored them from trash
> >> I've re-run osgeo setup and all works fine
> >> I hope this can help you
> >> Tyler Veinot-2 wrote
> >>> All;
> >>> Trying to install QGIS and QGIS Server using Osgeo4W installer on a
> >>> virtual
> >>> server running Windows Server 2012R2 and I keep getting an error "This
> >>> program can't start because zip.dll is missing from your computer. Try
> >>> reinstalling the program to fix this problem."
> >>> I don't have a zip.dll anywhere but I cannot find out what package
> >>> installs
> >>> it.
> >>> Anyone else run into this? Any solutions?
> >>> Thanks;
> >>> Tyler
> >>> _______________________________________________
> >>> Qgis-user mailing list
> >>> Qgis-user at .osgeo
> >>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> >>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> >> Antonio
> >> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
> > Qgis-user at .osgeo
> > Qgis-user at .osgeo
> Hi Lukas,
> It is the same error I read in my insallation Yesterday,
> If you unlock and Erase-restore the files msvcr and msvcp from
> c:/Windows/system32, then you reinstall from osgeo all works fine
> Regards
> Antonio
> Antonio
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20181017/1ec91b42/attachment.html>
