[Qgis-user] OSGeo4W install on Windows Server 2012R2
Antongeo76
antoviscomi at gmail.com
Wed Oct 17 08:29:53 PDT 2018
you're welcome!
Tyler Veinot-2 wrote
> All;
> Thanks it is working now
> Tyler
> On Wed, Oct 17, 2018 at 7:11 AM Antongeo76 <
> antoviscomi@
> > wrote:
>> Winiwarter, Lukas wrote
>> > Hi Tyler, Antonio,
>> > I run into the same issue with "zip.dll" when trying to install QGIS
>> > 3.2.3-1 or 3.2.3-2 from the network installer on Win10. The error
>> > message reads (in German):
>> > crssync.exe - Systemfehler
>> > Die Ausführung des Codes kann nicht fortgesetzt werden, da zip.dll
>> nicht
>> > gefunden wurde. Durch eine Neuinstallation des Programms kann das
>> > Problem möglicherweise behoben werden.
>> > And after pressing ok on the popup, in the Setup window:
>> qgis-common.bat
>> > exit code -1073741515
>> > However, installing qgis-ltr (2.18) works fine.
>> > best,
>> > Lukas
>> > On 17.10.2018 07:42, Antongeo76 wrote:
>> >> Hi Tyler,
>> >> I'd yesterday I'd trouble with install on windows 7
>> >> Well I find that something wrong QGIS 3.2.3 as QGIS Master
>> >> don't start an come out with a Windows error message referred to
>> absence
>> >> of
>> >> qgis.dll…
>> >> Well,
>> >> I identified that the conflict were whit
>> >> msvcr110.dll
>> >> msvcp110.dll
>> >> I've unlocked this two dlls and erased them
>> >> Then I've restored them from trash
>> >> I've re-run osgeo setup and all works fine
>> >> I hope this can help you
>> >>> All;
>> >>> Trying to install QGIS and QGIS Server using Osgeo4W installer on a
>> >>> virtual
>> >>> server running Windows Server 2012R2 and I keep getting an error
>> "This
>> >>> program can't start because zip.dll is missing from your computer.
>> Try
>> >>> reinstalling the program to fix this problem."
>> >>> I don't have a zip.dll anywhere but I cannot find out what package
>> >>> installs
>> >>> it.
>> >>> Anyone else run into this? Any solutions?
>> >>> Thanks;
>> >>> Tyler
>> >>> _______________________________________________
>> >>> Qgis-user mailing list
>> >>> Qgis-user at .osgeo
>> >>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> >>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> >> Antonio
>> >> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
>> > Qgis-user at .osgeo
>> > Qgis-user at .osgeo
>> Hi Lukas,
>> It is the same error I read in my insallation Yesterday,
>> If you unlock and Erase-restore the files msvcr and msvcp from
>> c:/Windows/system32, then you reinstall from osgeo all works fine
>> Regards
>> Antonio
>> Antonio
> Qgis-user at .osgeo
> Qgis-user at .osgeo
Antonio
