[Qgis-user] topological editing don't works as expected
Antongeo76
antoviscomi at gmail.com
Wed Oct 17 02:30:33 PDT 2018
Hi all,
in QGIS 3.2.3 as in MASTER
I need to edit a polygon shapefile with topological editing active
-I set snap options with tolerance 1m to my layer
-I active topologica editing an spapping on intersection
-I try to add a vertex on a polygon and move it for adjust boundary
well
-the vertex is added only on one of two coincident polygon boundary
-then when I try to move the added vertex this reshape only one of two
polygon...
I expected that topological editing still works as in QGIS 2,
where when I add a vertex and move it the reshaping acts on both
polygon who share the boundary I
want to reshape
there is someone else that has noticed the same anomaly
Regards
Antonio
Antonio
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
