[Qgis-user] OSGeo4W install on Windows Server 2012R2
Antongeo76
antoviscomi at gmail.com
Wed Oct 17 13:49:24 PDT 2018
You're welcome Hugo
However you've choose the stand-alone package
Regards, Antonio
hugonbg wrote
> Thank you, Antonio!
> I found another solution:
> I installed "QGIS-OSGeo4W-3.2.3-1-Setup-x86_64.exe" to see if it was not a
> problem in Windows 10, it installed and worked perfectly. I checked that
> in
> the bin/ folder there was the zip.dll.
> So I installed QGIS 3.2.3 via OSGeo4W and I marked all the packages that
> 'ZIP' in the name, this way it installed normally and did not display any
> errors. Now in Osgeo4w bin folder has a zip.dll.
> Regards, Hugo
> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
> Qgis-user mailing list
> Qgis-user at .osgeo
Antonio
