[Qgis-user] OSGeo4W install on Windows Server 2012R2
Winiwarter, Lukas lukas.winiwarter at tuwien.ac.at
Thu Oct 18 05:36:20 PDT 2018
Hi all,
I can confirm this works, it seems to be this package in the network
installer:
Libs --> libzip-libs
can we add this to the dependencies of QGIS, so it gets selected
automatically?
Best,
Lukas
On 17.10.2018 21:02, hugonbg wrote:
> Thank you, Antonio!
> I found another solution:
> I installed "QGIS-OSGeo4W-3.2.3-1-Setup-x86_64.exe" to see if it was not a
> problem in Windows 10, it installed and worked perfectly. I checked that in
> the bin/ folder there was the zip.dll.
> So I installed QGIS 3.2.3 via OSGeo4W and I marked all the packages that
> 'ZIP' in the name, this way it installed normally and did not display any
> errors. Now in Osgeo4w bin folder has a zip.dll.
> Regards, Hugo
> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
> Qgis-user mailing list
