[Qgis-user] OSGeo4W install on Windows Server 2012R2
Antongeo76
antoviscomi at gmail.com
Thu Oct 18 06:16:24 PDT 2018
Winiwarter, Lukas wrote
> Hi all,
> I can confirm this works, it seems to be this package in the network
> installer:
> Libs --> libzip-libs
> can we add this to the dependencies of QGIS, so it gets selected
> automatically?
> Best,
> Lukas
> On 17.10.2018 21:02, hugonbg wrote:
>> Thank you, Antonio!
>> I found another solution:
>> I installed "QGIS-OSGeo4W-3.2.3-1-Setup-x86_64.exe" to see if it was not
>> a
>> problem in Windows 10, it installed and worked perfectly. I checked that
>> in
>> the bin/ folder there was the zip.dll.
>> So I installed QGIS 3.2.3 via OSGeo4W and I marked all the packages that
>> 'ZIP' in the name, this way it installed normally and did not display any
>> errors. Now in Osgeo4w bin folder has a zip.dll.
>> Regards, Hugo
>> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
>> Qgis-user mailing list
> Qgis-user at .osgeo
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Qgis-user at .osgeo
Hi Hugo,
this issues it seems to be fixed...
there are a ticket closed here
https://issues.qgis.org/issues/20112
if don't you can reopen it and replay with your solution/proposal
Regards
Antonio
Antonio
