[Qgis-user] topological editing don't works as expected
DelazJ delazj at gmail.com
Thu Oct 18 01:14:55 PDT 2018
Hi Régis,
The issue priority is already set as high, tagged as a regression,
mentioned (and argumented) in the QEP related to the vertex tool. We are in
bug fixing time. What is missing? An interested dev?
IMO, the vertex tool refactoring brings nice features but having used it
more and more these last days, I find that we lose lot of handy features
and working with it in master is not that straightforward. And this has
nothing to do with changing habits.
I'm afraid that releasing 3.4 LTR with these issues (topology, vertex
editor, adding simply a vertex on an existing segment...) would not help
people that do daily digitizing work. Just my opinion.
Regards,
Harrissou
Le jeu. 18 oct. 2018 à 09:54, Régis Haubourg <regis.haubourg at gmail.com> a
écrit :
> Well, we can raise its priority and call developpers that are funded
> currently byt QGIS.org to work on it.
> Régis
> Le jeu. 18 oct. 2018 à 08:40, Alexandre Neto <senhor.neto at gmail.com> a
> écrit :
>> Well, if there's a ticket already, there's not much more we can do.
>> Unless someone is willing to sponsor that work/fix.
>> Best regards,
>> Alexandre Neto
>> A qui, 18/10/2018, 05:57, Antongeo76 <antoviscomi at gmail.com> escreveu:
>>> Alexandre Neto wrote
>>> > I can confirm that adding a new vertex to a polygon does not create
>>> > vertexes on other other polygons.
>>> > You need to create a node on the other polygon, and then snap it to the
>>> > first. Only then the topological node move work on both polygons.
>>> > Not sure how it worked on 2.18, may be considered a regression.
>>> > Alexandre Neto
>>> > A qua, 17/10/2018, 10:30, Antongeo76 <
>>> > antoviscomi@
>>> > > escreveu:
>>> >> Hi all,
>>> >> in QGIS 3.2.3 as in MASTER
>>> >> I need to edit a polygon shapefile with topological editing active
>>> >> -I set snap options with tolerance 1m to my layer
>>> >> -I active topologica editing an spapping on intersection
>>> >> -I try  to add a vertex on a polygon and move it for adjust boundary
>>> >> well
>>> >> -the vertex is added only on one of two coincident polygon boundary
>>> >> -then when I try to move the added vertex this reshape only one of two
>>> >> polygon...
>>> >>       I expected that topological editing still works as in QGIS 2,
>>> >>       where when I add a vertex and move it the reshaping acts on both
>>> >> polygon who share the boundary I
>>> >>       want to reshape
>>> >> there is someone else that has noticed the same anomaly
>>> >> Regards
>>> >> Antonio
>>> >> Antonio
>>> >> Sent from:
>>> http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
>>> >> _______________________________________________
>>> >> Qgis-user mailing list
>>> > Qgis-user at .osgeo
>>> >> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> >> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> > Alexandre Neto
>>> > @AlexNetoGeo
>>> > http://sigsemgrilhetas.wordpress.com
>>> > http://gisunchained.wordpress.com
>>> > Qgis-user at .osgeo
>>> In 2.18 adding a vertex on a shared boundary,
>>> This vertex becomes automatically shared too
>>> There is a ticked on qgis issues
>>> https://issues.qgis.org/issues/18046
>>> Regards
>>> Antonio
>>> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
>>> Qgis-user at lists.osgeo.org
>> Alexandre Neto
>> @AlexNetoGeo
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20181018/9a8336ff/attachment.html>
