[Qgis-user] topological editing don't works as expected
Régis Haubourg
regis.haubourg at gmail.com
Thu Oct 18 00:53:30 PDT 2018
Well, we can raise its priority and call developpers that are funded
currently byt QGIS.org to work on it.
Régis
Le jeu. 18 oct. 2018 à 08:40, Alexandre Neto <senhor.neto at gmail.com> a
écrit :
> Well, if there's a ticket already, there's not much more we can do. Unless
> someone is willing to sponsor that work/fix.
> Best regards,
> Alexandre Neto
> A qui, 18/10/2018, 05:57, Antongeo76 <antoviscomi at gmail.com> escreveu:
>> Alexandre Neto wrote
>> > I can confirm that adding a new vertex to a polygon does not create
>> > vertexes on other other polygons.
>> > You need to create a node on the other polygon, and then snap it to the
>> > first. Only then the topological node move work on both polygons.
>> > Not sure how it worked on 2.18, may be considered a regression.
>> > Alexandre Neto
>> > A qua, 17/10/2018, 10:30, Antongeo76 <
>> > antoviscomi@
>> > > escreveu:
>> >> Hi all,
>> >> in QGIS 3.2.3 as in MASTER
>> >> I need to edit a polygon shapefile with topological editing active
>> >> -I set snap options with tolerance 1m to my layer
>> >> -I active topologica editing an spapping on intersection
>> >> -I try to add a vertex on a polygon and move it for adjust boundary
>> >> well
>> >> -the vertex is added only on one of two coincident polygon boundary
>> >> -then when I try to move the added vertex this reshape only one of two
>> >> polygon...
>> >> I expected that topological editing still works as in QGIS 2,
>> >> where when I add a vertex and move it the reshaping acts on both
>> >> polygon who share the boundary I
>> >> want to reshape
>> >> there is someone else that has noticed the same anomaly
>> >> Regards
>> >> Antonio
>> >> Antonio
>> >> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
>> >> _______________________________________________
>> >> Qgis-user mailing list
>> > Qgis-user at .osgeo
>> >> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> >> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> > Alexandre Neto
>> > @AlexNetoGeo
>> > http://sigsemgrilhetas.wordpress.com
>> > http://gisunchained.wordpress.com
>> > Qgis-user at .osgeo
>> In 2.18 adding a vertex on a shared boundary,
>> This vertex becomes automatically shared too
>> There is a ticked on qgis issues
>> https://issues.qgis.org/issues/18046
>> Regards
>> Antonio
> Alexandre Neto
> @AlexNetoGeo
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20181018/bc81a655/attachment.html>
