[Qgis-user] topological editing don't works as expected
Alexandre Neto
senhor.neto at gmail.com
Wed Oct 17 23:39:38 PDT 2018
Well, if there's a ticket already, there's not much more we can do. Unless
someone is willing to sponsor that work/fix.
Best regards,
Alexandre Neto
A qui, 18/10/2018, 05:57, Antongeo76 <antoviscomi at gmail.com> escreveu:
> Alexandre Neto wrote
> > I can confirm that adding a new vertex to a polygon does not create
> > vertexes on other other polygons.
> > You need to create a node on the other polygon, and then snap it to the
> > first. Only then the topological node move work on both polygons.
> > Not sure how it worked on 2.18, may be considered a regression.
> > Alexandre Neto
> > A qua, 17/10/2018, 10:30, Antongeo76 <
> > antoviscomi@
> > > escreveu:
> >> Hi all,
> >> in QGIS 3.2.3 as in MASTER
> >> I need to edit a polygon shapefile with topological editing active
> >> -I set snap options with tolerance 1m to my layer
> >> -I active topologica editing an spapping on intersection
> >> -I try to add a vertex on a polygon and move it for adjust boundary
> >> well
> >> -the vertex is added only on one of two coincident polygon boundary
> >> -then when I try to move the added vertex this reshape only one of two
> >> polygon...
> >> I expected that topological editing still works as in QGIS 2,
> >> where when I add a vertex and move it the reshaping acts on both
> >> polygon who share the boundary I
> >> want to reshape
> >> there is someone else that has noticed the same anomaly
> >> Regards
> >> Antonio
> >> Antonio
> >> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
> >> _______________________________________________
> >> Qgis-user mailing list
> > Qgis-user at .osgeo
> >> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> >> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> > Alexandre Neto
> > @AlexNetoGeo
> > http://sigsemgrilhetas.wordpress.com
> > http://gisunchained.wordpress.com
> > Qgis-user at .osgeo
> In 2.18 adding a vertex on a shared boundary,
> This vertex becomes automatically shared too
> There is a ticked on qgis issues
> https://issues.qgis.org/issues/18046
> Regards
> Antonio
Alexandre Neto
@AlexNetoGeo
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20181018/b292e637/attachment.html>
